Thanks Neil.
Assembly 2.
While the weather is still a bit full on, a bit more time spent in the warm on the assembly..
All the required gaskets are supplied..
Fitting the Front Cylinder Gasket.
Fitting the Rear Cylinder Gasket – and cleaning out the debris, not sure how all that ended up in there..
Fitting the Gasket to the Valve Chest.
Installing the Graphite Yarn (supplied) around the Piston Rod (there is a 'shoulder' in there to stop it going right through into the Cylinder), then..
pushing the Graphite Yarn into the Cylinder Gland and tightening up.
the same for some Graphite Yarn for the Valve Chest (again a 'shoulder' inside the 'gland housing' to stop it going right through into the Valve Chest).
Assembly so far 1. ( Still some touching up needed here).
Assembly so far 2.
Regards.
Allan.
Edited By Allan. on 15/02/2014 11:55:20
