Another little update to finish the Con Rod.
This has taken a while to do from start to finish but was a great exercise, maybe I should have restarted after making the error with the thickness of the fork (disappointed that I messed up on one of the easiest bits), but have learned lots again through doing it. Thanks again to those that gave all the advice and especially Jason for the overall method of how to go about it…
I would be very careful next time in the corners of the taper and hope it would turn out better – having made the fork too thin made the whole thing more difficult…
Starting to cutaway the Con Rod fork.
The Con Rod fork so far after some more filing.
The filing buttons made for the Con Rod Fork.
The filing buttons in place on the Con Rod Fork. Another silly but this time slight mistake in that the buttons were just slightly too large which gave a slight flat spot at the end to try and smooth out. Something I'll remember to double check next time.
The finished Con Rod (fitted to the Piston Crosshead) 1.
The finished Con Rod (fitted to the Piston Crosshead) 2.
The finished Con Rod (fitted to the Piston Crosshead) 3.
The finished Con Rod (fitted to the Piston Crosshead) 4. You can see in this photo how I messed up on the taper.
Have to make the bush for the little end next..
Regards.
Allan.
