The Con Rod 1. (Mild Steel)
A quick update – sorry I'm back looking for advice / comments already! I was in, failed miserably and out of the worship so quickly today, the kettle had barely boiled…
Although I have gained some more valuable experience this morning, unfortunately of the bad kind though, but all part of the learning process – I suspect mostly down to me somehow and part my budget drills – again.
I've been having trouble drilling in steel from the beginning and this bar for the Con Rod is by far the biggest lump of steel I have tried to work with. The first attempt at drilling the through hole at the fork end on the Bench Drill and the drill bit again seemed to not want to know (I made sure everything was all clamped as tight as it would go this time) and then the bit snapped again. This was with a 2mm and then exactly the same thing happened again with a 2.5mm bit – the bench drill at its max speed of 2,500 rpm., both bits part of my 'budget' set and new. The drill itself was making a horrible rattling noise, even with the centre drill, not the motor but the table it seemed. So I thought I would try it on the mill – I love the mill I have it seems to be an excellent bit of kit – but the drill bit would not move through at all. This was again one of the budget set and again unused. Next try was with one of the 'individual' bits I had bought, this time it was lovely and smooth no vibration and the drill started to move through the steel but, within maybe 2 or 3 seconds, no more than that, the drill had gone bright red and melted in half and a 'red bubble' had momentarily appeared at the hole for a second, it was that hot, that quickly – ie so not snapped this time, see photo. Checking back there was no mention of it being HSS so just a 'standard' type I assume. The mill was running at close to 2000 rpm. It seems at the very least obvious now that the budget set of drill bits are not much use for anything. Does anyone have any tips where to buy good quality bits on line at a good price or advise what I should be using? I'm assuming they should be at least HSS steel or even better? Can anybody see if it was me at fault? The other thing to mention is that although I have had one 'budget bit' snap on the Lathe they have generally been ok then for some reason, although I have had a feeling some of them were not sharp even at first use – been drilling at about 700 rpm on the Lathe with the small bits. Any suggestions would be welcome – don't be stupid and buy cheap drills might seem appropriate! But I thought I would ask in case I am out with the drilling speeds or something?
The Con Rod drill bit failure.
So I'm hoping for a better outcome when I try again with some better quality drill bits..
Buying cheap drills seems to have been a big mistake in my original setup and definitely something to avoid in the future, even allowing for my bad technique they've definitely not helped I think…. ( Anyone like me just starting out may want to take note..)
Allan.
