Hi Jason
I guess then it remains to conclude then and not unreasonably, that Stuarts – as of now – have changed drawings and castings without giving due credit to that fact compared to old to new purchasers? The design has changed it should be clear to all.
We all know over the years that many drawings have mistakes in them – including my own – but the biggest 'crime' to my mind is when that mistake is allowed to perpetuate without alteration or at least an indication as to the anomalie.
Sometimes we have to accept the fact that we've made something wrong – either the wrong dimension firmly fixed in our heads – done that more than once!, sometimes it's because we read the drawing wrongly (definitely done that a time or two) or sometimes because the drawing is downright incorrect. It's the latter that is the most frustrating and particularly so to those early to machining who have just found that the part they have made is unfit for purpose and even more so to those of us who feel we 'should have seen it' but didn''t.
To have to make something over again is always a frustrating situation, especially if you think you are close to getting something ready to run. We are all different in our approach but we can – indeed should – learn from mistakes either by our own hand our that of others. Remaking a part is part of the process – annoying but a fact of machining life.
In this instance my view is to rectify what's wrong with the model as built – to me it doesn't look that far off so rather than focus on drawing dimensions which are conflicting and confusing it's to look at the situation and try to recover with as little input as possible. Getting the drawing dimensions 'correct' is for the next builder unless as already said it's Arthurs desire to get it absolutely correct to print – in which case which one and for which castings??
I well remember my early days with LBSC's Pansy 0-6-0. I took the frame drawing at face value and drilled all holes as called out. As other parts progressed it became apparent that all the brake hangar holes were incorrect. I borrowed a set of the relevant ME mags that covered it expecting to find an errata. Well it was there but only on the last paragraph of the last installment – something like " some may have found the brake hangar holes are in the wrong position but not to worry, just plug them and redrill in the correct place" I wouldn't mind betting those drawings still carry that mistake.
Arthur should do what he feels best – I know what I would be doing at this point
Regards – Ramon
