Posted by JasonB on 08/03/2021 13:29:38:
Clamp to cross slide with packing or to the Vertical slide of you have one. Flycut the end. Put DTI in lathe chuck and adjust bar's position until dti shows it's true and ctr drill with drill in spindle. I have used the wooden block method Ramon mentions in the past when I did not have a fixed steady for the Emco
Strictly speaking the holes do not need to be spot on but it's handy for measuring tool projection though that can be got around by turning down a section around the toolbit hole to a known diameter
Is a 1" bar going to be of use on your cylinders as it won't fit!. 3/4" would allow it to pass through the core (I think) and allow room for a few cuts & swarf
Edited By JasonB on 08/03/2021 13:31:20
I made a start on the boring bar, by drilling the centres. I used the vertical slide method, although it was quite tricky. I put the bar in the 3-jaw chuck, and then offered the vertical slide up, making sure the bar seated in one of the slots. Once everything was clamped up I checked the top surface and side with a dti, and it was quite a way off in terms of not being parallel with the bed. I couldn't really get it right to the dti, yet it slid in and out of the chuck quite freely.
Anyway, I figured that the most important thing was concentricity with the chuck right at the end, so I fixed the dti in the jaws and got both ends to within 0.001" all the way around:
Then undid all that good work by fly cutting the end!
Then re-did the centering (I need to learn to think the order of things through more carefully), and centre drilled:
When both ends were done, I put the bar between centres. Side to side, on the top and side edges, I'm getting pretty much no deflection of the dti, but about 0.004" when I turn it on its axis:
I don't suppose it matters too much, since the cutter will be rotating around whatever virtual axis it has at that point, and it won't be moving axially anyway?
I could really do with making a proper holder for the dti in a chuck for these concentricity measurements, not sure if there's a simple plan out there – or I could 3D print something.
Assuming the above is OK, the next job will be to mill a flat for the carrier, and a flat for the grub screw hole, and to make the cutter hole. Then I think that's about it.
BTW, for the boring operation, I was thinking of fitting my old 3-jaw chuck over the live centre, and using the jaws to contact the carrier (if it fits). I think it would save me messing about with bits of wire to stop it flapping about?
