Continued with de-scaling the wheels. I’ve run out of grinding bits for the Dremel, so have had to pause until new ones arrive next week.
Gave me chance to consider the barring slots again – I think they will have to be a separate insert after all to to space constraints at the rim. I think I could possibly get away from laser-cutting by turning an insert from mild steel – or mill a ring using the R/T, then fit it with JB Weld, then cut the slots. I suppose the insert would have to be perhaps 1 mm or so deeper than the slot depth to keep everything looking like a one-piece casting. Ideally I’d paint it final colour before milling the slots to save a load of masking. I like the look of plain metal on the machined slots.
