Stuart Twin Victoria (Princess Royal) Mill Engine
Home Forums Work In Progress and completed items Stuart Twin Victoria (Princess Royal) Mill Engine
Viewing 25 posts - 1,001 through 1,025 (of 1,233 total)
  • #637005
    Dr_GMJN
      @dr_gmjn
      Yes, I’ll have to check what size hole is in the cap. It might be 1.5mm
      I might continue with plastic today. I’ve got two Airfix Spitfires (both of which are terrible kits for one reason or the other),
      and yes I’m still doing the equally terrible Airfix Vulcan. For reasons I’m not entirely clear about, I started scratch-building some bomb-bay detail. They are incredibly complicated, and the standard kit is almost completely devoid of detail…
      Ramon Wilson
        @ramonwilson3
        Are those 1/72 scale Spitfires? I thought the 1/48 kits they produce were supposed to be some of their better mouldings. 1/72 is far too small for my eyes now, even 48th is pushing it on the smaller types.
        Lovely work on the bomb bay – just the sort of modelling I like to do myself but shame it's all rarely seen once the model is on it's feet. Have decided my next build (Trumpeter 1/32 F-100F) will be OOB – no after market save he exhaust and a closed cockpit – at 78 detailing at length is just too time consuming.
        Once the Phantom is on it's base I'll pop a pic or too up.
        #637033
          Posted by Ramon Wilson on 10/03/2023 11:32:05:
          You mean that you don't hang them off the ceiling with bits of fishing linewink 2
          Although I was more into cars and AFVs before the figure modelling I do like to see models before they are painted as you get a better idea of the work done when you can see the plasticard, photo-etch, resin (kit & 3D printed), etc in the flesh.
          #637050
          Dr_GMJN
            @dr_gmjn
            Thanks both – they are 1:72 Spitfires. The Mk1 panel lines are horribly deep, so I'm experimenting with partially filling them with surfacer. The Mk.22 has a horribly moulded nose, which required a lot of flatting, filling and re-scribing to get right.
            I got a resin printer for Christmas, and I CADded up a trolley for the Blue Steel missile included with the Vulcan (I also made some bomb-bay parts for the Vulcan on it). I scaled online photos and got some key dimensions from a museum. I was quite pleased for a first attempt.
            I was considering mounting the Vulcan vertically on a wooden base, supported by four acrylic or stainless steel rods up the jet pipes.
            Anyway, I've done my work hours this week, so I'll head into the garage now before it gets too cold, and try to get the other bearing done…
            Edited By Dr_GMJN on 10/03/2023 13:54:02
            #637095
            Dr_GMJN
              @dr_gmjn
              Got the other bearing made this afternoon. It was easier the second time around.
              I incremented the tool until it was the right fit, but this time I used the top slide dial to maintain a constant width side-to-side. I should have done that before, but I find that if I've been away from the workshop, it takes a while to get back into thinking things through properly.
              I also opted to make the flanges oversize in terms of width, and then faced to size on a mandrel. I did it this way becasue I found it very difficult to measure the flanges while grooving the slot and then parting off.
              It turned out that the first pedestal I made, which ended up scrap, was actually very useful in clamping the shells together while doing all this:
              So these are they:
              The running fits seem fine, but I can't help thinking the surface finish could be better on the journals and shaft – it's pretty smooth in rotation, but if it's moved axially…I can tell it's been turned. Anyway, I think it's OK overall.
              #637110
              Hopper
                @hopper
                Posted by Dr_GMJN on 10/03/2023 19:44:17:
                If you want smoother on future jobs, try reaming the holes in the bearings for a smoother finish and use emery cloth to get the final smooth finish on the shaft. This gives you very fine control over the final shaft size for clearance too.
                #637121
                Dr_GMJN
                  @dr_gmjn
                  Posted by Hopper on 10/03/2023 21:26:59:
                  Thanks Hopper.
                  I don't have a 1/2" reamer, so the advice was to bore them instead. That worked OK.
                  I did use wet and dry with some metal polish on the shaft bearings when I made the shaft.
                  To be fair they're probably absolutely fine. It would just be nice to look at them and see a mirror finish is I guess where I'm at.
                  #637129
                  Hopper
                    @hopper
                    I've had good luck buying used machine reamers off eBay, old UK and Australian made ones. And if you can work in metric, whole sets of new Chinese "chucking reamers" are available amazingly cheaply and seem to work well enough for the home workshop. Well worth building up a collection.
                    Or you can use a redneck hone for finishing bores. A length of wooden dowel with a hacksaw slot in the end with a strip of emery paper wrapped around it, fed by hand into the hole as it is spun in the lathe. Or held in a pistol drill and used like a brake cylinder hone. Sounds bodgy but works quite well.
                    I am sure your bearings will work fine as is though. They look pretty nice in the pics, and pics tend to make such things look worse rather than better.
                    Edited By Hopper on 10/03/2023 23:17:35
                    #637395
                    Dr_GMJN
                      @dr_gmjn
                      I'll try the eccentrics next. I've got the castings, and I think the bar is what I got for the sheaves:
                      I'd appreciate some help, becasue I find the description of how to machine the sheaves confusing to say the least.
                      For the straps (which Id like to fully machine), I was going to do it like this:
                      1) Clean up the castings with files.
                      2) Set in milling vice with the clamp hole faces vertical & drill the holes.
                      3) In the same setup, cut the straps in half with the slitting saw
                      4) Solder & bolt the strap halves together.
                      5) Make & fit a centred wooden plug, mount strap into the 4-jaw.
                      6) Remove plug and bore the hole.
                      8) Face the outside face.
                      9) Make a mandrel, clamp strap around it, and face opposite side.
                      10) Mount in rotary table (on stub) and fully machine the outside and stub faces. Drill stub holes.
                      I'm unsure at what point to machine the internal groove (presumably using a modified boring bar which I know will be a challenge). I could do it after 8), but then I'm unsure how to get it perfectly central when the faces aren't to size yet.
                      Sheaves – No idea what the best way is, given I've got a mill, and the article description seems to be for a lathe and vertical slide – is there a better way given more equipment?
                      Thanks!
                      #637404
                        I was saving these pics from when I did the Victoria for a rainy day but may as well post them now though the rain may be coming.
                        looks like I first just held it roughly in teh 3-jaw to clean up one face then would have flipped it over and using some parellels faced the other sid eto bring it down to final width
                        Held in the mill vice mill the edges to width, mill the fixing surface flat,
                        drill tapping right through, clearance half way and tap
                        Saw in half then mill the sawn face still in the vice to clean it up
                        Mill the other face to clean up, two packers under the milled bolting faces will hold it level.
                        Screw together, hot glue a bit of scrap to the face and mark ctr position – can be done with edge finder & dro if you want
                        LIGHTLY holding in the 4-jaw so as not to distort the casting set your marked ctr to run true, parallels behind again then pop off the hot glue and bore.
                        With a suitable tool of known width and top slide set parallel to lathe axis touch off on front of work and zero dials. move tool in 1/2 its thickness plus half strap thickness and cut your groove it can be a bit deeper than the dimension
                        Mill the rod lug flat and drill
                        Make a top hat bush to clamp the strap down and mill the outside curves (different strap) you may need to file close to the screws.
                        #637409
                          I've never done an eccentric with the separate groove and loose ring like TC shows, this is how I did the victoria one to Stuart's drawing where it is all one piece
                          Face your stock and turn down to a few thou over size for about 1/8" longer than the required strap width allowing for the short raised boss too. Turn down to final diameter enough to be beyond the ridge. Thenn use aparting tool first plunging and then moving side to side to bring the areas either side of the ridge to diameter
                          Use the strap to gauge diameter, having the groove a bit deeper ensures you are testing fir on the running surfaces
                          Saw off from parent bar with enough for the longer boss, reverse in chuck and skim the face (3-jaw will do) now mark a horizontal ctr line on work, rotate chuck 90degrees and mark another line 1/8" higher
                          Punch that mark and then holding I the 4-jaw set the mark to run true, parallels behind work or if your stock is large like mine push that against jaws
                          Drill and bore to a close fit on your crankshaft before moving to the mil and drilling & tapping for grub screw(s)
                          Put a stub of round bar in chuck or collet and using teh grub screw fit eccentric to that so you can then turn the bosses with a round nosed tool.
                          #637421
                          Dr_GMJN
                            @dr_gmjn
                            Thanks very much Jason. Makes sense.
                            I guess you machined the outer strap profile in the CNC machine? I'd just put mine in the R/T.
                            Also, rather than mark out the eccentric offset with a height gauge, I guess I could do it in the mill, and centre drill the offset hole?
                            I'll not bother with the separate ring – doesn't seem any point in not doing it like you suggest.
                            I just checked, and my slitting saw is not quite big enough to go through both sides of the strap when central in the vice – the end nut hits the side of the vice. I guess I could slit saw as much as I can, then finish the last mm or so with the hacksaw? Then mill all faces.
                            #637425
                            Dr_GMJN
                              @dr_gmjn
                              I was given this Sandvik internal bar holder, but I've only got a couple of internal threading tools (which I've never needed):
                              Does anyone know where I can get grooving inserts (5mm shank, about 1.3mm wide, 1.8mm deep) for a decent price? Google doesn't seem to know. Thanks.
                              #637430
                              Baz
                                @baz89810
                                Jason can you tell me where you got your lovely internal grooving tool from?
                                #637445
                                  Grooving inserts came free from another member but look to be the same as the Sandvik one shown by Doc
                                  The outer profiling in that image was indeed on the CNC as I was making it from scratch and did not have a photo of the casting being done. but you can mount in a similar way on the R/T or if you have a small chuck like this
                                  Yes you can finish the cut by hand if needed and mark out on the mill
                                  #637506
                                  Dr_GMJN
                                    @dr_gmjn
                                    Those inserts are quite expensive at about £25 each, plus a 6mm holder (mine is 5mm) is about £70.
                                    I wonder if a holder made from square bar, drilled out with a grub screw would do for this?
                                    a L/H insert (threading type) might also be useful for machining the rope grooves in the flywheel?
                                    #637507
                                      I just hold mine in a bit of bar with a grub screw. You can also just grind the end of an old ctr drill or milling cutter like a little parting tool and hold that in a bar drilled at right angles to tale it and a grub screw in the end to retain it.
                                      I would just set your DCMT holder at an angle and use that for the rope grooves, it will be a lot more rigid.
                                      #637510
                                      Dr_GMJN
                                        @dr_gmjn
                                        Posted by JasonB on 13/03/2023 13:05:10:
                                        Yes I might just use a bar then. If I was going to grind a drill or something, I'd just use an old HSS boring bar and grind that.
                                        I think the issue I will have when machining the O/D of the flywheel is that the ML7 doesn't really have the capacity to hold a tool rigidly at that diameter. I would have to check that though.
                                        #637959
                                        Dr_GMJN
                                          @dr_gmjn
                                          Looking at the strap castings – I’m hoping it’s right that they’re not handed? So presumably a slight offset is required on the eccentric arms and/or operating levers to compensate?
                                          #637973
                                            Probably easiest to make the straps and rods the same and then sort out the slightly different offsets when you come to make the rocker arms and pin, a slightly longer pin on one engine would be the neatest way to do it.
                                            Not sure what your silver soldering is like but you may want to consider deviating from the brazed on fork to the ends of the rods and do them just as flat strips with a hole in the end and rounded over. You can then make the rocker arm 1/4" thick and put a slot in the end for the eccentric rod to go into. I've done that on the Victoria, Real and James Coombes as I really don't like the Stuart bolted together forked end to the eccentric rods
                                            rocker vic.jpg.
                                            #637994
                                            Dr_GMJN
                                              @dr_gmjn
                                              OK thanks Jason. Yes, extending the shaft I think is the best option – that's what I meant by an offset on the operating lever. I think the original plans call for the crank in the bar to be screwed together? (I've not got the plans to hand right now). BTW I don't have any silver soldering kit yet.
                                              Also, you previously mentioned D&Ting one side of the eccentric straps – presumably this is just temporary for profiling, and a bolt and locknut would be used for the final assembly? I thought I read somewhere that studs weren't used in steam engine castings (not sure why). I guess having two square blocks either side of the joint suggests a bolt and nut fixing was the intention?
                                              I got a grooving tool from Cutwel, and made a holder this evening. I added a brass pin to stop it rotating (I assume that's what the chamfer is for), and a grub screw for axial location:
                                              Tried it on some scrap brass tube, seems to work fine.
                                              I used on off-cut from the steel I boght for the connecting rods. It seemed to mill quite nicely for once, so I guess that bodes well for when I get on to those.
                                              #638024
                                                Doc, I built the Victoria quite closely to the Stuart Dawings and with most of their castings and they show the strap tapped for bolts.
                                                Full size practice and on quite a few models is to have a good sized hole so we would ream if possible if not a good drilled hole will do. You should then make "fitted bolts" which have their shanks turned to a close fit in the holes. The head of the bolt is usually stopped from rotating be bearing up against a flat on the strap and then the two halves held together with nuts and lock nuts I have done this on several engines including the recent James Coombes II, sorry for the grainy photo is did not have a clear closeup of final assembly with the right bolts, also my Fowler's straps (locknuts still to go on).
                                                TC does show botls right through so you can use temporary ones while machining.
                                                #638035
                                                Dr_GMJN
                                                  @dr_gmjn
                                                  Right – so get some square or hex. Steel and turn the bolts to the drilled/reamed hole, then thread just the end?
                                                  Could I then get away without temporarily soldering the straps?
                                                  Thanks.
                                                  #638234
                                                  Dr_GMJN
                                                    @dr_gmjn
                                                    Made a start on the eccentric straps:
                                                    Filed the flash off:
                                                    Put in the chuck and faced each side to thickness:
                                                    They seem OK:
                                                    Now to fathom the offsets for milling the various faces and find some bolts.
                                                    #638235
                                                      I tend to start with round stock, turn the shank, thread the end and then mill the head, that way you get a nice crisp head to whatever size you want and don't have to use the 4-jaw. Should be able to use just the bolts & nuts to complete machining.
