Stuart Twin Victoria (Princess Royal) Mill Engine
Home Forums Work In Progress and completed items Stuart Twin Victoria (Princess Royal) Mill Engine
Viewing 25 posts - 976 through 1,000 (of 1,231 total)
  • #636646
    roy entwistle
      @royentwistle24699
      Welcome back, I was wondering where you'd got to.
      Roy
      Dr_GMJN
        @dr_gmjn
        Thanks guys. Good idea with clamping the outside Jason. I’ll do that.
        #636776
        Dr_GMJN
          @dr_gmjn
          Soldered the bars together, milled them square and centre drilled them. Then back into the 4-jaw chuck ready for some action with my shiny new (non-tapered) grooving tool:
          Ironic I was waiting for warmer weather, and now it’s colder in the garage than ever.
          #636799
          Dr_GMJN
            @dr_gmjn
            Hmm just wondering if I should saw the block in half to get less overhang, and do each bearing in separate set-ups?
            I centre-drilled each end to give me that option.
            #636808
            Hopper
              @hopper
              Seems like the best way to make sure those shoulders are square would be to take a facing cut across them with a regular turning tool. So you would need a right hand and a left hand turning tool to do each shoulder respectively, but then you would know it is square to the job's axis.
              What is the purpose of the groove? Is it just to make sure there is clearance around the corner so the bearing sits on the centre of the turned section and not on the corners if the radius there is bigger than the radius on the bearing pillow block?
              If so, you could leave the groove off all together and just make sure the edges of the holes in the pillow block are suitably chamfered to clear. Or you could make the clearance with the turning tool at the end of the final facing cut of they shoulder on the bearing by taking it in a few thou deeper and then taking a short cut longitudinally away from the shoulder.
              Grooving/parting tools will often wander about a bit and are not always to be trusted!
              #636813
                Can't you just slide the bar back into the chuck further, looks like it will pass into the hole in the middle of the chuck, that will also help hold the two parts together. Not sure if one of those ctr holes is on the joint look at the pick of it being drilled.
                As Hopper says the undercuts each side of the waist are not really needed, just make sure the edges of the pedestal hole are heavily deburred. And don't make it too narrow that it won;t fit over the paint.
                #636815
                Dr_GMJN
                  @dr_gmjn
                  Thanks guys. Yes, looks like one of the drillings isn’t on the line. It’s odd because I used an edge finder to get the centre for drilling (the thicknesses of the bars was identical) and then a dti on a centering rod in the lathe, plus checked the faces with the dti as a double-check, and all was good.
                  Anyway, well spotted.
                  #636817
                  Ramon Wilson
                    @ramonwilson3
                    Some thoughts
                    The over hang is too long
                    The centre, however gently applied, will act as a wedge applying a separating pressure on the weakest point – the soldered faces. The act of turning the groove will apply more pressure on the joint too.
                    Once the OD is turned the 'clamp' of the bearing pedestal needs to be tight otherwise the drilling will apply more pressure to the now very narrow soldered faces
                    Parting off is likely to be a nightmare. with the 'clamp' in place.
                    Some further thoughts
                    Cut off enough to make one bearing (twice)
                    Hold in mill vise with soldered faces clamped, face, drill and bore. If no boring head drill to within .5mm on diameter and return to lathe in four jaw. Bore to size. Much easier to centralise part on mill than four jaw with the outside surfaces known to be parallel to the split line.
                    Make simple mandrel with very slight taper that bearing pushes on and very gently face each end true to bore.
                    Make parallel mandrel and clamp washer and clamp firmly on mandrel to turn OD to finish size.
                    If the soldering was efficient the bearing can then be held on an expanding mandrel to turn to finish width and any steps etc possibly required on each end.
                    As always, your choice of course, but having been down the route before without success I'd seriously not be thinking of repeating the exercise.The above will give the certainty of accuracy, with the least stress on the split line but then – what would I know wink
                    Good luck with it Doc
                    Just seen your last post. Easily rectified in the mill op
                    Edited By Ramon Wilson on 09/03/2023 08:00:03
                    #636818
                    Dr_GMJN
                      @dr_gmjn
                      Hopper – I made the previous two without much problem. IIRC the solder failed, but it was close to the jaws so turning the OD wasn’t an issue. The only problem we’re the tapered walls with the old parting tool. If I shorten the bar and do each bearing separately, the chuck would approximate a milling vice, and I’d also know the OD and ID were concentric.
                      BTW Jason, the hole in the chuck won’t allow the bar to pass through.
                      #636821
                        Ah yes looking back you have a threaded body chuck so spindle nose is probably in the way though would roughing the ends down to round first then allow it to be moved further in?
                        Using the Pedestal and cap as a clamp was just a belt and braces suggestion while boring in case the joint was suspect, could be removed before parting and I do tend to have a gap between cap and body so a tight fit would result. Though if it is a suspect joint a tapered mandrel could also pop it apart. Take your pick.
                        Not sure if you have collets or if they would go large enough and how true they run but that is another way to hold things, turn OD and waist, part/saw off and face to length then hold in a collet to bore which holds the two halves together.
                        #636847
                        Dr_GMJN
                          @dr_gmjn
                          Thanks all. Firstly, I was puzzled by the off-centre drillings, so I took the part out of the chuck and checked again. I think they are fine; it must have been the angle the photo was taken at:
                          I do have collets, but they’re no big enough.
                          Since I think I still have the first pedestal I made (which I rejected because of the bolt/washer overhang). I can use that as a clamp for drilling and boring – also parting? If necessary I can flat the mating faces a bit to get a tight fit. I might offset the split lines from the clamp/work to get a more positive location as well.
                          I don’t have a boring head for the mill, but even if drilling almost to size, as mentioned, wouldn’t subsequent use of a tight fitting or expanding mandrel in the lathe then defeat the objective of retaining some radial clamping? I’d have thought using the 4-jaw for the entire process would be less risky in terms of the part coming apart?
                          #636857
                          Ramon Wilson
                            @ramonwilson3
                            Not saying that radial clamping is wrong – just, in my opinion, unnecessary and certainly unwieldy using the bearing pedestal. Nothing wrong with using a four jaw either but on a mandrel all bearings are identical to the bore with nothing more required to achieve accuracy one to one than setting it in place on the mandrel.
                            It's just a different way of going about it without the possibility of creating slight inaccuracies that will manifest them selves on assembly.
                            Besides there is no way of 'knowing' if a part in a four jaw is axial especially if the chuck is old – it's a facility I try to avoid if there is other means. Though I use it a fair bit in other ways I have never used it to make identical bearings because of that possibility and to me its always easier to bring the outside to a bore – on a mandrel – than the other way.
                            I've made a fair number of bearings from quite small 3/16 diam to the ones on the Corliss quite large by comparison in the method suggested. Only had one part in two by machining on the mill as the reamer went in due to the the faces not clamped between the vise jaws and one split on an expanding mandrel due to a poor solder joint.
                            There's a fair bit of work in achieving the fits necessary in bearings to ensure good alignment but as already said the choice is down to the individual.
                            #636858
                            Dr_GMJN
                              @dr_gmjn
                              Thanks Ramon. Looking back over the discussions on the shaft etc. before I had a break, I honestly can’t remember all the suggestions and pros and cons of shaft first/bearing first. The thread got rather disjointed with me going from one job to another for some reason. Anyway, somehow I ended up with shaft first.
                              I’m happy I can bore the bearings to be a tight running fit on the shaft, ready for lapping when everything is in place on the beds. But…splitting the bearings and removing the solder will inevitably make them tighter on the shaft when re-fitted, and, effectively the mating faces will be slightly higher in the pedestals and caps. I guess I will need to flat the housing faces to suit, and as IIRC Jason and/or yourself said – use the bearing cap lock nuts to adjust?
                              I think that’s the theory, and really the only way to maintain a true cylindrical journal on assembly (even if it’s not a complete cylinder)?
                              #636870
                              Ramon Wilson
                                @ramonwilson3
                                I advocated the 'bearings first' method Doc simply because it is much easier to try a pre-made bearing on the shaft than to use the shaft as a plug gauge with it's attendant risk of wringing the part in the chuck due to it's length.
                                The very method of soldering the parts together introduces the situation you refer too. However, the solder thickness should be quite thin but does always leave a residue on breaking apart. lapping the solder residue away on something flat will increase the tightness of the bearing as you say. Though miniscule there will always be a slight 'out of circular hole' as a result so that's when a little scraping or fine removal with wet and dry on a smaller diameter shaft comes in – just in the bottoms of the bearing shells and not on the sides.
                                If you do this right you should not have to lap the bearings to the shaft on assembly. This is why I suggested to you to make the base and build the engine up as you go – dealing with any such misalignment in turn before moving on to the next addition.
                                These three bearings were done exactly as described and not line bored in situ. The shaft is a good fit laterally and the bearing shell tops slightly tweaked to allow the bearing caps to pull up without the shaft binding – it runs very freely in fact.
                                BTW you may note that the bearings are in place to act as 'masks' whilst painting the base. Once removed the paint was cleaned off the bearing shells with a soak in cellulose thinner – perfect fit without having to make allowances for paint
                                #636872
                                  Many a bearing cap has a good gap between it and the lower housing so you often see nuts and locknuts on the studs as they are not fully tightened down but just enough to allow the shaft to rotate freely in the bearings. From that it can be deduced that the bearings themselves to not have to be closed right up so the split faces touch. Some engines will have shims between cap and housing but less so or had shim placed before the bearings were bored..
                                  Take a look through that old book pdf and you will see the gaps and on the larger engines there was also facility to close up the bearings front to back as they wore or were rescraped.
                                  #636895
                                  Dr_GMJN
                                    @dr_gmjn
                                    Ramon, Jason,
                                    OK so as I see it, if I bore the bearings to be a good fit (maybe a little tighter than optimum for now), then even after separation, the bores will be cylindrical (but individually not full half cylinders), and obviously exactly the same diameter they were before separation, and will therefore still match the shaft.
                                    So on re-assembly after removing the solder, assuming the bearing was an accurate fit in the housing, no further work should be required, since the only change would be a gap between the bearing faces – the cap-pedestal gap would still be zero on tightening?
                                    If the bearings were to wear, then the cap faces could be thinned, allowing the bearings to be tightened?
                                    But, in full-size practice, the caps would be thinned by default and shimmed back to size initially, since this would simplify maintenance (no machining, just shimming)?
                                    This would make sense.
                                    #636900
                                      Well if they are bored tighter than optimum they will still be tight on assembly
                                      #636907
                                      Dr_GMJN
                                        @dr_gmjn
                                        Posted by JasonB on 09/03/2023 15:53:09:
                                        Yes, I was assuming I’d use some metal polish and oil to lap the shaft and bearings together once finally in place on the base, to eliminate any slight mis-alignment that might creep in.
                                        #636909
                                        Ramon Wilson
                                          @ramonwilson3
                                          Yes – Jason Is spot on here Doc, the cap just holds the bearings in place and should not distort them – if you think about it if the cap is fully tightened down to the housing/pedestal and the shaft is free to rotate then the shell must have a gap – the slightest distortion will tighten things up considerably – any wear cannot be taken up unless the cap is further reworked.
                                          The caps are usually relieved each side of the bearing cavity to allow this. 'Setting' the locknuts will soon reveal just how little movement is required between locked tight and running fits. IE the clamping pressure is entirely set by the bearing cap bolts.
                                          I thought you were aware of this situation.
                                          #636910
                                          Ramon Wilson
                                            @ramonwilson3
                                            Here you are this will explain it
                                            The locknuts on top or bottom is entirely up to you wink
                                            #636912
                                              I think Ramon is the same as me regarding polishing an assembly until it runs smooth, You really should be making the parts to run correctly and if on assembly the shaft is tight in the bearing it is not an issue with the shaft or the hole in the bearing but something else causing it to be tight and that is what needs to be rectified.
                                              For the same reason I'm not of fan of "motoring" an model to get rid of tight spots, that is the practice of fixing it up to a motor and running for an hour or so to wear off the tightness.
                                              #636981
                                              Dr_GMJN
                                                @dr_gmjn
                                                So, deep breath, and try again…
                                                I cut the block in half to stiffen everything up:
                                                Faced:
                                                Flange O/D turned from square:
                                                Set the grooving tool normal:
                                                I had to use back-gear to avoid chatter, but all ok. The recess was by far the hardest part. Once again I found it difficult to judge dimensions and simultaneously machine a width and diameter without going over or undersize on one or the other. Having the saddle stop at one end was fine, but it’s fresh air at the other end, and very easy to go too far in the width while getting the diameter. What I did was get the width right, then when the diameter was almost there, undersize each end to avoid the pedestal radii. This left a raised block in the middle, and I changed tools to a normal turning tool to reduce that until it was the perfect diameter to match the housing. All a bit sketchy I think, but it worked.
                                                Then clamped in the spare housing:
                                                Drilled and bored to a good running fit on the shaft:
                                                Then parted-off without issue. Again, judging and adjusting the cut to give the right flange dimension was very difficult:
                                                Here’s the result:
                                                Fit seems fine, runs smoothly enough with the cap screws loosely tightened, but binds slightly when fully tightened.
                                                So I’m calling that one OK. Now for the other side.
                                                #636998
                                                Ramon Wilson
                                                  @ramonwilson3
                                                  Good result Docyes – hope the second turns out as well for you.
                                                  #637000
                                                  Dr_GMJN
                                                    @dr_gmjn
                                                    Posted by Ramon Wilson on 10/03/2023 07:59:08:
                                                    Thanks Ramon. I really did pick a good time to start again -3 forecast for this evening…
                                                    I still need to drill the oil and anti-rotation holes. May have been discussed, but plan is to assemble, put in the mill and drill a 1mm hole through everything from the top (aligned with the existing oil hole in the cap). If the drill won’t reach the bottom I’ll have to remove the cap and then go through the bottom shell and housing with a drill appropriate for whatever brass or steel rod I can find. Then tap the rod into the housing with Loctite.
                                                    #637004
                                                    Ramon Wilson
                                                      @ramonwilson3
                                                      Well I don't envy you there Doc – the one thing I can say is I do have a warm workshop to hibernate in.
                                                      I guess that's as good a reason to 'hit the plastic' over the winter as any. Though not for the same reason I took a break from the marine engine for the same distraction and am just in the finishing throes of a 1/32 Phantom.
                                                      Take care with that one mil drill tonight – 1.5 might be a bit safer?
