Made a start.
Centred the brass block:
Drilled to 10mm so I could a) get a boring bar in, and b) give clearance for the crank spigot so I could test fit the crank shaft all the way along it’s journal:
Faced off to form a thrust face:
Then bored to a tight running fit on the crank:
Then took intermittent cuts on the square to form the o/ds of the bearing side faces:
Unfortunately this partially broke the solder joint; when I test fitted the crank again, oil slowly bubbled out of the joint.
Anyway, thought I might as well carry on, so formed the bearing holder groove with a parting blade – deeper cuts at each end:
Test fitted until the halves just about closed:
It fell apart after final parting, but after cleaning the faces it looked fine:
There is a bit of a gap left when the cap is screwed down to a good running fit. If fully tightened it gets a bit too tight for comfort (but still turns). I expect once it’s been lapped in it’ll be spot-on:
The parted-off face needs thinning a bit, but I can do that with wet & dry on the surface plate.
I did make a mistake and over-bored a bit of the block at first, but hopefully I’ve got enough left to clamp in the chuck and make the other. Anyway, so far so good. Thanks for the advice.
