Stuart Twin Victoria (Princess Royal) Mill Engine
Home Forums Work In Progress and completed items Stuart Twin Victoria (Princess Royal) Mill Engine
Viewing 25 posts - 926 through 950 (of 1,234 total)
  • #612950
      Posted by Zan on 10/09/2022 09:10:49:
      Agreed, my apologies I missed that photo but why then did doc say
      “Got the metric step diameters spot-on (at least to the 0.01mm accuracy of the calipers)” when there’s a micrometer I wouldn’t trust my mitutoyo calliper for measuring here but would use my digital Mitutoyo……. Still impressed though!
      One of my hobby-horses is the difficulty of getting high-accuracy measurements right. No criticism of Doc's work, which is much better than mine, but I fear he's stumbled into error by claiming an accuracy greater than that of his instrument! Although the resolution of his caliper is 0.01mm, implying an accuracy of ±0.005mm, Mitutoyo's stated accuracy is only ±0.02mm.
      I don't think the inaccuracy matters for what Doc is doing, but it might if several Docs were working separately to build a Princess Royal, each being responsible for various different parts to be brought together and assembled later. It doesn't matter because although Doc's slip gauge stacks aren't accurate in absolute terms, they ensure a high-level of repeatability in Doc's workshop, and I'm sure his finished engine will be wonderful.
      Historical diversion: I think the Princess Royal engine must be named after Queen Victoria's eldest:
      Her son is more famous!
      Pictures: Thomas Heinrich Voigt, Public domain, via Wikimedia Commons
      Zan
        @zan
        Doc, regarding tool bit grinding, you may like to see my post and phots of my simple grinder rest in this thread
        lathe  carbide tool issue
        sorry, can’t find out how to post a link to it
        please contact me if you want more details
        Edited By Zan on 12/09/2022 13:38:44
        #613235
        roy entwistle
          @royentwistle24699
          First impression of Queen Victoria's eldest, I thought she was holding a shotgun surprise
          #617534
          Dr_GMJN
            @dr_gmjn
            All, I think this might have been touched upon a while back, but I can't find where: I'm wanting to start the base for the model, and to do a parquet wood effect. I need to know the approximate scale of the model to get the floor looking right.
            Looking at the railing height, from floor to top rail, it's 3" or 76.2mm. A standard real-life height is about 1000mm, so this gives an approximate scale of 1:13
            I was given a load of birch wood sections, which I think may have been for OO gauge sleepers:
            Which are 4mm wide:
            One of the standard parquet floor wood sizes is 60mm x 210mm, so this would give me a scale of about 1:15. I'd say this is close enough for the job.
            Obviously I'd have to trim each piece to the correct length (about 15mm), but this would then double or even triple the number of strips I've got to work with. I'd need about 2500 to do the complete floor. I think it would look quite nice:
            My thinking is to print the CAD of the floor onto paper, align and glue the paper to the base with PVA. Then in turn PVA each strip in place over the paper. I think it would be strong enough, since I use PVA on paper ship models and there's no way they're ever coming apart.
            Any thoughts? Thanks.
            #617545
              I think PR was said to be about 1/18th and Goliath 1:24 and remember commenting that 3" rail height was a bit much as usual height is 3ft
              #617556
              Dr_GMJN
                @dr_gmjn
                Thanks Jason. From what I found online, top rails should be a minimum of 950mm above the floor, with 1000mm being common. Of course these are modern standards. Maybe there were none back when engines like this were used, and perhaps people were shorter?
                Whichever scale it is, it’s only a matter of about 0.5mm difference, and since I’ve got a shed load of 4mm strips I might as well use them. I’ll have to make some kind of length trimming jig for multiple strips, and get a very sharp saw…
                #617557
                Ramon Wilson
                  @ramonwilson3
                  Rather you than me from a patience perspective Doc but it's going to look impressive if you bring it off. I've done similar with 'decking' but with much longer pieces. Only thing I'd comment on is that the engine would be extremely unlikely to sit direct to the flooring – the flooring being brought to the engine foundations.
                  As an aside are you aware that if you pre-coat the part with PVA and let it dry you can activate it again with a hot iron? ie place the part in position hold an iron on for a few seconds and the part is stuck – Done this a lot with 1/32 and 1/16 ply reinforcing on balsa surfaces – works well and the technique might be of use to you.
                  Finally picked up on the Marine Engine – hope to see it through to finish this time – ha! says he!
                  Best – R
                  #617566
                  Ramon Wilson
                    @ramonwilson3
                    Further to your last post Doc I just did similar for the lagging on the marine engine
                    Just two pieces of balsa CA'd to a slip of Conti Board and a stop to give the length.
                    The major guide acts as a guide for the saw which is a Zona razor saw – finest TPI they do
                    That gave a consistent result but if I were doing 2500 pieces I would reinforce the end of the saw guide with something.
                    Hope that's of use too
                    #617642
                    Dr_GMJN
                      @dr_gmjn
                      Thanks Ramon. I wasn’t aware you could activate PVA like that. It might be good to get the whole lot layer out properly, then iron it. I know some PVAs are re-dilutable with water (Formula 560 Canopy Glue for example), whereas the outdoor stuff is obviously permanent. I always use the former for models because it gives you chance to correct things.
                      I assumed the beds wouldn’t be placed on wood, I suppose it’s a bit of modeller’s license. I guess you could say the pieces might have butted up to the bed frames? I was going to use plain wood, but then when I inherited these chips I thought it would be good to use them, otherwise they will be scrap.
                      I’d like to make a metal jig that holds at least 10 strips at a time. Shouldn’t be too difficult.
                      I’m also pondering whether to make the cylinder jackets out of wood, like your marine engine. I don’t really know how to fix them though. The brass band method can to my eyes look a bit “added on later”, especially the band fasteners when they screw into the cylinder casting.
                      Anyhow first I need to finish the bearings, the with the shaft done I can at least say the two halves can be linked, and that will be a decent step forward.
                      Cheers.
                      #617647
                      Ramon Wilson
                        @ramonwilson3
                        Hi Doc,
                        Yes if you could 'contain' all your small pieces from moving somehow you could indeed iron through them in a large area. I've not tried it on a paper substrate however so as with trying anything new a good test piece is well worth while beforehand.
                        I've used various PVA's over the years – my favourite (for aeromodelling) was Borden Wood glue, later renamed Humbrol Extra Bond. Both long extinct. Any of the 'TiteBond' adhesives are good PVAs but when I made the steam launch I tried the Titebond 3 (green label) water proof version. What impressed me most with using that was it's extremely quick (for PVA) grab time – now I don't use anything else. Might also be worth considering.
                        I usually mount my engines on a foundation of MDF set on the base proper. This can be worked to represent simple concrete foundation or separate blocks if desired, it's very flat, uniform and hard enough to withstand the bolting forces and any subsequent running. It would also mean you don't need to spend time fixing tiny pieces underneath the engine which will never be seen.
                        The wood lagging I've made for the marine engine is attached with CA to a 12 thou thick aluminium sheet lagging.. This was made from a paper template made in three parts off the cylinder block to achieve the expanded profile.
                        I've been drilling the head and fitting small bushes tapped 12BA for the holding screws today. I'll have to pop some pics up at some stage.
                        Best – R
                        #617661
                          A lot will depend on how you retain the cladding, the usual two straps and some round head screws may look a bit crude particularly if overscale for this engine. If you look at some of the larger full size engines then the brass is somewhat more detailed often having an "L" section that clips over the ends of the slats and at this size just bonding in 1/32" rivits would give a better size head than trying to use screws. Good example of it here on Simon's No4 and carried on on the next page.
                          The Titebond I, II & III glues are Alphatic resins which are a bit different to PVA and is one of the reasons for their faster grab.
                          Edited By JasonB on 18/10/2022 07:57:53
                          #617670
                          Ramon Wilson
                            @ramonwilson3
                            Posted by JasonB on 18/10/2022 07:56:46:
                            I stand corrected Jason blush
                            I have always thought of it as a 'PVA'. I have not used it as previously described for a PVA glue being reactivated by a hot iron so a test would be required to see if it acts in a similar way
                            I've stuck quite a few small strips of wood down to a substrate (usually birch ply) over the years though nothing quite like what Doc has in mind. These have mainly been decking on 'ship' models and have included black paper inserts between to simulate caulking. Adhesive has always been very thin cyano and application has to be done with care to ensure the CA does not get on to the top surface. It was always applied to the edge with the plank held in position beforehand and allowed to wick through underneath
                            The main thing to be aware of is the positioning of initial 'key' parts as any errors soon manifest themselves into a deviation from that desired. Same with the 'planks' or parts – any error in length or width quickly becomes obvious as the differences build up.
                            I admire Docs courage to having a go – it's a lot of pieces to fix over quite a large area and will require some quite accurate parts. Given that, I feel it would be best to cut them by 'machine' to ensure symmetry of length rather than by hand if possible. Thought also needs to be given to symmetry of the whole pattern if a border edging is to be done too.
                            A complex task but one that will be very impressive overall if done well – which I'm sure it will be having seen work done so far yes
                            Best – R
                            #617672
                              Agree any deviation in length even if only small will soon start to throw the pattern off, even consistantly butting the edges and ends together equally will be a challenge. Though more of a challenge wil be to do the T&G joints to ends and edgesdevil
                              I mostly use Titebond II for works and buy it in 1gal at a time, it also dries with less flexibility than PVA so is good for bent laminations. Their cold press glue is quite good for veneering and I usually use their PU for anything that may see the weather
                              The curved laminations and top were done with TBII on this, they are about 40mm squares of Ebony and Maple
                              This was cold press 24 pieces of maccasar ebony, about 1.4m dia, frame is steel also by me
                              #617694
                              roy entwistle
                                @royentwistle24699
                                Every engine house that I have been into has had tiled walls and floor. The place is flooded with condensate on startup and oil thereafter.
                                #617698
                                Ramon Wilson
                                  @ramonwilson3
                                  Yes I would agree with you on that Roy but I think Doc wants to make a representational model more than an accurate portrayal.
                                  It's a hard one to call – when I did the Corliss engine I pondered long and hard about how to do the base surface – in the end I came down to leaving it the plain formica layer to 'represent' a painted stone floor. I did consider scribing slab lines into the surface as I did on the Mc'Onie but even baulked at that in the end from fear of making an error and spoiling it – plain it was thendscn1009.jpg
                                  It's the same with a black and white tiled floor – those square pieces have to be perfectly sized and perfectly square to do the job well.
                                  Personally, I prefer to put the effort into the model and keep the base as simple as can be with easy cleaning in mind.
                                  #617708
                                  Dr_GMJN
                                    @dr_gmjn
                                    Thanks guys.
                                    Yes, it's just a wooden base that's got a bit more interest to it that I want. Nothing lost but some time if it looks rubbish; I'd just use a plain wooden one.
                                    Here's one you must have missed Roy!
                                    Object of the week – Mill Engine – Leeds Museums & Galleries
                                    #617710
                                      Ah but did the museum just put it on planks? It's original working enviroment may have been different
                                      #617713
                                      Dr_GMJN
                                        @dr_gmjn
                                        Posted by JasonB on 18/10/2022 13:16:06:
                                        Probably, but it's a fairly large working steam engine, bolted to a wood covered floor. Good enough for me!
                                        I was thinking of pasting brick paper around the inside of the wheel well to give a bit more interest too.
                                        I'll mess about with some CAD of different options, and might even try a small section of parquet flooring to see how it looks with the various features like Ramon's concrete MDF bases etc.
                                        I suppose I could get some 1" ply and make a temporary base for setting up. After all everything will need setting up again after painting. I can't finalise & paint the beds yet until I've figured out what holes will be needed for whatever cylinder drain pipework there will be.
                                        #617716
                                          I suppose you could have a "screeded" area that extends out beyond the base of the machines and a flush parquet walkway around and between them which would reduce the amount of work needed but still allow you a timber floor. Add a few gridded panels to cover pipe runs and that could look quiet good.
                                          Also worth bearing in mind that what may look like floorboards in mill buildings were infact "board on edge" where you would have substantial say 4" x 12" boards stood on edge and butted up to each other for a solid floor. These fetch a premium now for resawing into floor boards.
                                          If you are going for paper bricks you can also get good looking A3 sheets of parquet too.
                                          Edited By JasonB on 18/10/2022 13:53:04
                                          #617718
                                          roy entwistle
                                            @royentwistle24699
                                            All due respects Dr. but a museum is not a working environment.
                                            Roy
                                            #617719
                                            Ramon Wilson
                                              @ramonwilson3
                                              I can see your point Doc but even in a museum setting I would sincerely hope there was a very supportive foundation directly below those floor boards even if they are around 4-5inches thick.
                                              I would say that most full size engines of your build type were mounted on either concrete or stone block foundations which were usually, though not always, higher than the floor itself. Floor 'decoration' is another matter of course.
                                              Just had a quick look through a volume of the Textile Mill Engine which confirms this, some engines appearing to be directly mounted to the floor, others on 'plinths' of varying thickness. To my mind the plinth gives the engine another dimension so I've always done that. but it isn't something that's cast in stone (oops!)
                                              I'll look forward to seeing your result
                                              R
                                              #617721
                                                Though having just flicked through George Watkins' " the steam engine in industry" there are a few images in there of timber floors, plate 52 below would be closest to your engine.
                                                I did put my Filer & Stowell engine onto a wooden floor as I found old B&W photos that showed this. However they were often use din timber mills in the US so far more likely to have had the buildings constructed of timber than here
                                                Edited By JasonB on 18/10/2022 14:14:07
                                                Edited By JasonB on 18/10/2022 14:21:29
                                                #617731
                                                Dr_GMJN
                                                  @dr_gmjn
                                                  Thanks guys – I'll figure something out and see what it looks like.
                                                  Roy – OK, the museum isn't a working environment, but the image Jason just posted appears to be?
                                                  End of the day it's not a scale model of a specific engine, so if steam engines can be mounted on wood – or at least within a wooden floor environment – then why not do something a bit different?
                                                  #617733
                                                  Ramon Wilson
                                                    @ramonwilson3
                                                    Posted by Dr_GMJN on 18/10/2022 15:40:54:
                                                    Doc,
                                                    I quite agree for as though some of the larger engine houses show little evidence of wood flooring, quite a few of the smaller, such as the one in Jason's image, do.
                                                    Albeit an engraving, here's a good example that might be worth considering – not 'parquet' I know but a lot less work involved
                                                    #617734
                                                      I thought that was quite a large engine room as the flywheel is said to be 32ft dia and weighs 50T
                                                      Photo of a similar engine to Ramon's 2nd illustration here
                                                      Edited By JasonB on 18/10/2022 16:35:09
