Hi folks! I has worked with the cylinder block to final size. But i has a problem: The distance of inlet steam ports is not correct. It will be 5/64" inlet port + 5/64"+5/32" exhaust port + 5/64 + 5/64" inlet port for both high pressure/low pressure cylinders. I measured between outer inlet port and inner inlet port and got results: The outer distance between the two inlet port is 15/32" (correct distance) in both HP/LP and inner inlet port distance is difference both in HP and LP. HP has 37/128" and LP has 9/32", it must be 5/16" in inner distance between the two inlet ports.
Is it common the distance is not allways correct due wrong in casting?
Is it possible to make a carefull change to correct distance with a microscopic increased inlet port distance and change the distance in the "D" valve to keep correct overlap/keep the inlet ports closed in same time with the "D" valve in the center position?
I has not still created the exhaust port in the cylinder block.
Some idea and suggestions?
