Stuart Turner Castings
Home Forums Stationary engines Stuart Turner Castings
  • #62818
    Alan Worland 1
      @alanworland1
      I am gradually working my way through some of the larger castings and have found them to machine well with not too much to take off – until I came upon the cylinder!
      I have been removing something in the order of .030 – .060 off the various faces but the cylinder bore which finishes at 1.500 started off with a cast bore of about 1.150!!
      Thats an awfull amount of cast iron to remove – I had it all bolted to the large faceplate which required a consierable amount of balancing so I was keeping the speed low and as a consequence it took ages.
      Is this done for a reason?
      Alan Worland 1
        @alanworland1
        #62835
        Terryd
          @terryd72465
          Hi Alan,
          Which model is it you have? Stuart make a lot of kits.
          regards Terry
          Edited By Terryd on 20/01/2011 08:46:35
          #62898
          Alan Worland 1
            @alanworland1
            Hi Terry,
            It’s the No4 engine I have, it a ‘4’ cast in the cylinder so I guess it’s the right one.
            I initially thought it might be a common casting to be used with other designs?
            Just seems a lot of material to remove, I have left it 0.002 under for a final hone.
            Alan
          Home Forums Stationary engines Topics
