I got the message from Stuart Steam models around 4 hour after:
"If the burner is working correctly you should hear a gentle roar from the boiler, you can get various noises depending on how the jet is set up.
Here's how to get the correct burner set up.
Place the burner in the boiler, Start with the jet holder fully pushed into burner, turn the gas on fully and light the gas at the chimney, you should get a flame out of the chimney, then slowly lift the jet holder up from its bottom position in very small increments, fractions of a millimetre at a time, it will get to a point where the flame will disappear inside the chimney and you will hear a slight roar from the boiler, It can be quite quiet so don’t think the flame has got out, by carefully placing your hand above the chimney, without burning yourself you will be able to feel the heat still rising from the chimney, This will be just about the optimum position for the burner, If you go to far you will hear a war war sound, at this point if you push the jet holder down very slightly again this will be the right place for the burner. As the pressure in the gas cylinder decreases you may need to adjust the jet further."
I tried as shown here, but weak heat from burner , do not boil water fast contra consumption of steam.
Who are pleasant to sail steam tugboat with "Pulsejet" to keep boiler heat?
