My experiences with the cheap Chinese shell mills with APMT type inserts has been better than Jasons'. I have 5, two 40mm and three 50mm, they all fit snugly on their R8 arbors and run within 0.002" tir. One of the 50mm ones is not as good as the others, as it will not face and shoulder. The shoulders are sloping about 2 degrees. That one is labelled as such. They are cheap enough to have inserts for steel on some and for aluminium on others, saving the bother of changing inserts round. They all run on 22mm arbors, the 50mm size uses APMT/APHT16 and the 40mm use APMT/APHT11 inserts.
I also have Ceratizit, Maydown, Kennametal and Hertel shell mills, from 50mm to 80mm.
Collets in an ISO30 fitting mill should work just as well as they do in R8, as the taper is the same within a few minutes of arc. The only difference is that the drawbar thread, 12 X 1.75mm is coarser than the 7/16 X 20 UNF of the R8. Slightly more torque will compensate.
Edited By old mart on 13/12/2019 21:57:33
