Stuart S50 drawings in metric
Home Forums Stationary engines Stuart S50 drawings in metric
  • #69641
    Dismaldunc
      @dismaldunc
      Hello peeps, as the whole imperial 32/64 type thing just confuses the bejabers out of me I have redone the drawings for the above in metric ( which was a very dull thing to do) so If tanyone would like um in jpg form send me a message and they shall be yours.
      Duncan
      Dismaldunc
        @dismaldunc
        #74695
        harry willems
          @harrywillems33449
          Hello Duncan
          At this moment I am building the S50 mill egine.
          I want to ask you to mail the drawning in metric values.
          Thank you,
          Greetings Harry
          #74697
          Dismaldunc
            @dismaldunc
            Hi Harry
            I’ve sent you a PM
            Duncan
            #74699
            Stephen Benson
              @stephenbenson75261
              Wow that would be great the reason I stopped making the S50 and reason I swore I would never make another Stewart Model was the use of fractions took all the joy out of it. so I will message you right away
              #74740
              The Merry Miller
                @themerrymiller
                Hi lads,
                For those that are interested the link below will give you access to Tubal Cain’s very good notes and advice on building the S50, that’s assuming you haven’t already got the info.
                Len. P.
                #74744
                Roderick Jenkins
                  @roderickjenkins93242
                  Posted by The Merry Miller on 09/09/2011 21:00:59:
                  Hi lads,
                  Len. P.
                  Len,
                  How do you know where to find these re-prints?
                  perplexidley yours,
                  Rod
                  #74745
                  The Merry Miller
                    @themerrymiller
                    Hi Rod,
                    I just Googled “Stuart S50 with Tubal Cain” and up popped the link.
                    I did this about 4-5 months ago and printed off the whole article.
                    I’m about halfway through the build at the moment.
                    Len.
                    Night night.
                    Edited By The Merry Miller on 09/09/2011 22:42:25
                    #74747
                    Roderick Jenkins
                      Thank you, that works. I got a link from the forum to Westbury’s Centaur instructions which I downloaded.  I wonder what else is out there? Going to http://www.model-engineer.co.uk/wp-content/uploads/sites/4/documents/ doesn’t provide access.
                      Rod
                      Edited By Roderick Jenkins on 09/09/2011 23:37:20
                      Edited By Roderick Jenkins on 09/09/2011 23:37:44
                      #74754
                      steve 1
                        @steve1
                        try this link for a handy chart…../www.engineeringtoolbox.com/inches-mm-conversion-d_751.html
                        steve c
                        #74991
                        1
                          @1
                          Mornin’ all
                          I am looking to build a Stuart kit as my next step and I had a 10V in mind. Has anyone out there converted that kit’s drawings to metric?
                          Jim
                          #74997
                          Dismaldunc
                            @dismaldunc
                            Hi Jim
                            If you get the “building a vertical engine” book
                            It has all the dimensions in both metric and imperial
                            Dunc
                            #75016
                            1
                              @1
                              Ah, once again so simple if you know! The book was on my shopping list along with the kit.
                              Thanks Dunc. Once I have the 10 under my belt I may well be calling on you for a set of your S50 drawings.
                              Jim
                              #85406
                              Julian Siddle
                                @juliansiddle14518
                                Evening all, new to the forum, arrived here via a search for S50 drawings after a recent ebay purchase of an incomplete S50 circa 1950's. I have downloaded and read Tubal Cain's notes from the link kindly given above by Len. Very helpful and detailed, thanks to all involved.
                                Although I am pretty confident with the imperial measurements and the notes cover much of the dimensions, the engine did not come with any drawings. Would it be possible for someone to message me regarding getting these, imperial or metric.
                                Many thanks again
                                Jules
                                #85414
                                chris stephens
                                  @chrisstephens63393
                                  Hi Guys,
                                  For those less computer literate and want to read more of the S50 build write up, substitute 2,3,4 etc etc for the "1" just prior to the .pdf in the link.
                                  http://www.model-engineer.co.uk/wp-content/uploads/sites/4/documents/sally-1.pdf
                                  http://www.model-engineer.co.uk/wp-content/uploads/sites/4/documents/sally-2.pdf
                                  and so on till you have the whole thing.
                                  chriStephens
                                  #85417
                                  Terryd
                                    @terryd72465
                                    Posted by Julian Siddle on 21/02/2012 22:00:11:
                                    ………………………….Although I am pretty confident with the imperial measurements and the notes cover much of the dimensions, the engine did not come with any drawings. Would it be possible for someone to message me regarding getting these, imperial or metric.
                                    Many thanks again
                                    Jules
                                    Hi Julian,
                                    If you approach Stuart with your problem they will be sympathetic. I had a similar problem, contacted Stuart and they sent a copy of the drawings by post at no charge. Excellent service.
                                    Best regards
                                    Terry
                                    #85483
                                    Sub Mandrel
                                      @submandrel
                                      Interesting, the 10V came with 'bilingual' drawings for the imperially challenged.
                                      I keep a calculator to hand in the workshop, so if there's a fraction I don't know in my head I just do 32/64=0.500"
                                      Convert to metric is just 32/64*25.4=12.7mm
                                      Is that really all that hard to do?
                                      Norman Pinkney
                                        @normanpinkney15518
                                        Hi guys,
                                        Does anyone have a set of metric Stuart S50 diagrams they can send me? Youngest son is keen to give engineering a go and I fear dealing with imperial measurements for his first serious encounter will put him off for life!
                                        Thanks,
                                        Norman
                                      Home Forums Stationary engines Topics
