Alan,
would it not also be possible to solder in a plate after cutting out the pocket using soft solder such as 60/40 (electrical solder) with a melting point of around 190degrees C. Just preflux with a good plumbers flux. wrap a small serpent of fine solder wire below the plate infill, and heat gently until solder emerges from the seams. Newer lead free solders also have even higher working temperatures but are not necessarily eutectic and are a bit more difficult to work with, but others are.
Soft solder is very underestimated and underused these days given modern adhesives, but it has advantages and has been proven to be able to last for centuries. Not sure about the lasting qualities of resins and other polymeric adhesives. I’m not up to date with developments in the Auto industry now, but does anyone know if radiators are still soldered in the traditional way or can the newer resins be used to bond the parts as they have such high pressures and temps to work with?
You obviously make your own choices but look at all the alternatives and their consequences.
Best regards
Terry
Edited By Terryd on 16/01/2011 22:44:59
