I wasn't sure to post this up, but it is really all part of the engine build so here goes – apologies to the some that will likely not be interested…
Making the Between Centers' Boring Bar…
I didn't have a 3/8 inch bar (that would have been a perfect size for the bearings) – so I had to turn a larger bar down a bit… The Final Bar length will be 8.5 inches..
The bar turned to 9.5mm.
Centering the bar on the mill ready to drill the tool bit hole. I've ordered some 1/8" round tool steel.. Drilled the hole to 3.2mm. Don't have the tool steel yet to test fit – may have to open out a bit perhaps…
In case anyone is wondering about the paper – my V Blocks did not come as a pair…
Center Drilling first..
Tool Bit hole drilled to 3.2mm.
I had marked horizontally through the end diameter when drilling the tool bit hole to use to rotate 90 degrees to drill the grub screw hole..
1st time I had tried tapping on the mill – and it was great.. 2.5mm M3 Tapping Size.
Test fitting the M3 grub screw. The length had to be cut to fit…
The grub screw in and cut to a length that will not protrude outside of the OD when tightened on the tool steel..
The finished Between Centres Boring bar – waiting for the tool steel and grinder to turn up. (3MM drill bit through the tool hole to illustrate only..)
Found a grinder for £20 – don't know what it will be like – and £2 for some tool steel. Hoping now i will be able to grind a suitable cutting edge when it arrives. Its already been dispatched apparently..
Allan.
Edited By Allan. on 14/05/2014 16:10:46
