Hi Ian
Yes, as Jason says – talking about studs just for clamping. I have a feeling whoever designed my clamping studs has never had to use them, I nearly always have to use more than one 'clamp' per stud to be able to tighten.. A continuous thread would seem to make much more sense for that job..
Hi Jason
Thanks, I've used Tracy a lot so its good to have that link, I think they will be useful..
Ready for some more soldering now after doing the fixing holes on the other bearing cap. Been wondering a bit how the initial drilling of the bearing 'permanent pairs' through on the join is going to go… and hoping that at least having the cobalt bits now will maybe increase the odds of success… The gunmetal was 'grabbing' at the bit when simply drilling the bearing caps – imagine it may be worse on the join. Yet another first at that..
No washers on the bearing cap drawings by the way – but something to remember to check before spot facing in the future!
A few more photo's finishing the fixing holes..
The second bearing cap with fixing holes and spot faced..
Test fitting both bearing caps – just lined up by hand, not fixed yet 1.
Test fitting both bearing caps – just lined up by hand, not fixed yet 2.
Test fitting both bearing caps – just lined up by hand, not fixed yet 3.
The photo shows it doesn't line up perfectly on the housing, bit too long on the one end – but it's not too bad..
Allan.
