Just managed to do the fixing holes and spot face one of the top bearing 'caps' today.. Not long to do..
Checking the size of the fixing nuts a/c for spot facing – used a 10mm End Mill..
Setup used on the Mill to drill the 4mm 2BA Clearance Holes for the bearing 'caps' – and to spot face..
I must get around to lengthening the threads on my clamping studs to avoid having to use so many clamp pieces..
Couldn't use my vice, when I looked carefully the jaws do seem to sometimes be 'rising' or at least pushing the work up when tightened – as Jason suggested they might earlier.. I know the studs won't fit properly unless the holes are bang on vertical.. Have to get a new decent one soon..
The work turned around to do the other side..
Test fitting on the bottom bearing half (just lined up by hand, not fixed) – far from perfect, but not too bad I hope – ready for soldering together, drilling and boring (1)..
Test fitting on the bottom bearing half (just lined up by hand, not fixed) – far from perfect, but not too bad I hope – ready for soldering together, drilling and boring (2)..
The other one to do now.
Regards.
Allan.
ps. can someone yell at me if to many 'small' updates – or if I should go back to just updating when whole parts are finished as I mostly did with Victoria. So quick and easy to upload too much…
Edited By Allan. on 04/05/2014 19:09:59
