Stuart M.T.B. 1a
Stuart M.T.B. 1a
Home Forums Model Boats Stuart M.T.B. 1a
Viewing 3 posts - 26 through 28 (of 28 total)
  • #554821
      If you did go with Helicils then M2.5 metric or #3-48UNC would be closest to the original screw diameter and pitch, As you say the very small whitworth threads would be hard to find a helicoil for so probably the only way to stay with 3/32" whit would be to drill out quite a bit larger and bond in some inserts with JBWeld made to fit with the 3/32" thread.
        Posted by BasKo on 19/07/2021 17:26:51:
        I also checked helicoil, but it looks like that this system isn’t available for 3/32“ threats.
        True … but I would personally consider a UNC HeliCoil to be a significant upgrade.
        BasKo
          @basko
          Thanks to all of you! You really helped me out!
        Home Forums Model Boats Topics
