Noel –
Yes: most digital calipers and micrometers offer readings in both inches and mm, selected by a button; and some (not all) also give fractional-inch readings.
I have one of those Tracy Tools poster-sized conversion-charts in my workshop, hanging from a dress-hanger so I can turn it easily to read the tapping-drill charts on its reverse.
The problem I have is not Imperial / Metric as such. It's with these blasted centimetres insisted on by the schools, rag-trade and natural-history radio programmes!
I know the cm is slightly more anthropocentric hence perhaps more comprehensible for everyday use like shopping, than those tiddly little millimetres; but I am used to both Imperial and proper metric units, at work and in my hobbies, so find it rather hard to grasp.
Usually I convert them to mm, knowing 200 of those is about 8" and a 19mm A/F spanner fits a 3/4" A/F nut.
The use of Inches and two-s scale fractions thereof in model-engineering is convenient for scaling from prototype, but does lead to awkward things like 17/64".
There are good and points in all measurements system, which are all artificial anyway; but if we are to work to metric units then yes, we should use sensible conversions, not always the arithmetical ones; and with due consideration of the consequences.
I don't know that 256 factor. .That is new to me. I use 1 inch = 25.4mm then round if and as necessary; but let's think about that 17/64" fraction I gave, quite randomly.
17/64" = 0.265" = 6.75mm: so 6.5mm or 7mm.
Not much difference there, no; insignificant on many components. However even that tiny change like might have a significant effect on something like a wall thickness, the overall sizes of available ball-bearings, or the meshing of gears (or choice between imperial and metric gears).
Straight conversion and rounding might not always be as simple as first appears.
Incidentally, the BA system is not "pseudo-metric" as Noel says, but is metric though inch-described; with its full range by geometrical progression. Whilst not matching completely and none interchangeably, some of the common BA sizes do have M-series equivalents close enough for direct replacement without major re-designing. The accepted tapping-drill diameters for BA threads are quoted in mm to 0.1mm steps too, so are easily obtainable.
