Stuart D10 Metric Plans
Home Forums Stationary engines Stuart D10 Metric Plans
Viewing 25 posts - 1 through 25 (of 65 total)
  • #158964
    JBFlies
      @jbflies
      I have a set of castings and about to finally start work on making my D10. I say finally because this has been a long time in the gestation. The plan that came with the castings many years ago are in Imperial units. I am now firmly embedded in metric. If someone had a copy of the D10 plans in metric that would be most helpful.
      JBFlies, NZ
      JBFlies
        @jbflies
        #158973
        Nick_G
          @nick_g
          I may be wrong on this but I 'think' all Stuart plans are still in imperial.
          I say this as I very recently bought a set for a James Coombes engine and they are imperial.
          Regards, Nick
          Edited By Nick_G on 29/07/2014 09:28:52
          #158976
          Ady1
            @ady1
            Divide by 256 and adapt as required?
            3/8" is 256/8=32 *3 =96 =9.6mm, say 9.5mm
            7/64 is 256/64=4 *7=28=2.8mm, say 3mm
            etc etc
            #158979
            Circlip
              @circlip
              3/8" = 0.375" = 9.525mm
              Multiply all dimensions by 25.4 and work to all decimal places otherwise you'll find your D10 won't work. "Rounding" dimensions only works when all the corresponding fits are compensated.
                0.1mm = 4 thou. They add up rapidly.
              Regards Ian.
              Edited By Circlip on 29/07/2014 10:09:03
              #158980
              Anthony
                @anthony
                I have built the Stuart S50 and had the same problem with the plans being Imperial. I bought a vernier gauge from Warco for about £32 odd that is capable of showing measurements in Imperial, metric and fractions of an inch – brilliant and worth every penny.
                #158985
                simondavies3
                  @simondavies3
                  Ady, the conversion factor is 25.4, not 256…
                  #158986
                    Simon,
                    We've trodden this path before …
                    Please see my posts on this thread.
                    Ian S C
                      @iansc
                      A 6" steel rule won't cost too much, a cheap set of digital calipers not much more.
                      In a number of industries these days one of the early lessons for apprentices is imperial weights and measures.
                      Ian S C
                      #159001
                        You also need to decide if you just want to work in metric measurement in which case its justy a simple mathamatical conversion or press of a button.
                        Or if you want a fully metric engine then you need to throw out all the barstock and most of the fixings supplied. No point in using 3.175mm stock and trying to use your ISO metric M3 die on the end. So you need to go out and source 3mm dia rod and alter the matching parts to have 3mm drilled or reamed holes and also buy suitable fasteners.
                        Working through the drawings and doing your own conversions will give you a better understanding of the parts and methods needed to machine them.
                        #159005
                        Svarven
                          @svarven
                          Stuart have a building guide book, with metric dimensions for no 10.
                          TEE Publishing ISBN 1 85761 096 2 revised 1995
                          #159006
                          Martin 100
                            @martin100
                            Despite imperial and metric dimensions being in the number 10 book the drawings supplied with the more recent stuart castings explicitly say they supercede all other issues of the drawings. They are now only dimensioned in imperial.
                            There is a dimensional error in the number 10 book, it is mentioned in a forum, maybe even this one but I can't recall what it is.
                            There is also at least one and maybe two dimensional errors in the text of the (extremely useful) online Harold Hall series on building the 10.
                            Edited By Martin 100 on 29/07/2014 15:11:12
                            #159007
                            Another JohnS
                              @anotherjohns
                              Hi JBFlies;
                              Whilst I wish for metric-only, I'll admit that my first locomotive was built in inches with BA fasteners.
                              Now, one project is metric plans, but the other inch; I simply take a calculator, convert, write on plans with pencil.
                              If you allow me to step on my soapbox, I think that ALL plans for Model Engineer stuff should be in metric – it's the way of the world, and we need more model engineers, so why the "inch" barrier? (note – no "one is better than the other" just "that's the way it is&quot
                              JohnS.
                              #159014
                              Stephen Benson
                                @stephenbenson75261
                                I have no problems with imperial decimals but I find fractions a real pain to use so I wrote a Delphi program to convert the fractions on my SS50 over time I added a few more bells and whistles but its still works well it is on my web site for download
                                Edited By Stephen Benson on 29/07/2014 16:13:30
                                #159018
                                  Buy the little Andrew Smith as revised by Pengwern book on building the 10V. It has full bilingual plans in it and all the critical dimensions for the double 10 are the same as it's just two 10Vs side by side.
                                  JBFlies
                                    @jbflies
                                    Great comments and I can see both points of view. I thought that more modern ST plans would have been converted but understand that is not the case.
                                    I quite like the thought of building in Imperial for the extra challenge. Can't be too hard.
                                    #159102
                                    RICHARD GREEN 2
                                      @richardgreen2
                                      Each to his own, but it's Imperial all the way for me !!
                                      If you want to convert to Metric just buy a calculator, or a digital vernier, and work it out, what's the fuss all about ?
                                      Richard.
                                      #159105
                                      Stephen Benson
                                        @stephenbenson75261
                                        Posted by RICHARD GREEN 2 on 30/07/2014 10:48:58:
                                        Richard.
                                        Nothing difficult about imperial decimals its fractions that are the pain on a simple threaded rod part 20 S50 there are the following dimensions 2 15/32, 5/32, 1 5/16, 3/32, 1/2, and .07 dia try working that out on your digital vernier.
                                        If we want new people to join our hobby we need to speak their language
                                        Edited By Stephen Benson on 30/07/2014 11:25:53
                                        #159110
                                        Gordon W
                                          @gordonw
                                          This old thing again, Whats the problem ? 27/64 is about 15 thou less than 28/64, which is 7/16, inch sign not working. But to be serious I am a great believer using the system the item was built to in the first place. Also use the original dimns. eg 6" x 1" and not some pseudo accurate conversion. What scale would a 5" loco be in metric dimns?
                                          #159127
                                          Ian S C
                                            @iansc
                                            There are some who still use imperial measurements, those blokes on the left hand side of the Atlantic (USA I thinkcheeky). Ian S C
                                            #159129
                                            RICHARD GREEN 2
                                              @richardgreen2
                                              Come on boys , this is simple stuff,
                                              Stephen,   2. 15/32"  = 2.468", put this into a digital vernier, press the mm button, = 62.69 mm,
                                              Richard.
                                              Edited By RICHARD GREEN 2 on 30/07/2014 14:53:47
                                              #159131
                                              Stephen Benson
                                                @stephenbenson75261
                                                Posted by RICHARD GREEN 2 on 30/07/2014 14:47:25:
                                                Richard.
                                                Hi Richard you have missed my point no problem working with 2.468 it is the converting of 1000's of fractions per Stewarts drawing into decimals that is painful, machine tools have dials now I know I will never buy another set of castings from Stuarts
                                                Edited By Stephen Benson on 30/07/2014 15:24:58
                                                #159134
                                                RICHARD GREEN 2
                                                  @richardgreen2
                                                  Stephen, every engineer should have a small book of decimal equivalents,
                                                  1/64" = .0156
                                                  1/32" = .0312
                                                  1/16" = .0625
                                                  1/8" = .1250 etc etc
                                                  Just use a calculator………………………………..
                                                  #159135
                                                    Converting fractions to decimals usually means pursuing excessive accuracy. The fractional dimensions on a Stuart drawing are intended to be 'rule dimensions' and the parts should be made to fit each other.
                                                    These kits were originally designed for builders who probably didn't own a micrometer or a vernier caliper and certainly wouldn't have had handwheel dials on their lathes!
                                                    For those unfamiliar with fractions a calculator does make it easy. 15/64" literally is 15 divided by 64 = 0.234"
                                                    When converting to metric I use: fraction x 25.4, so (15/64) * 25.4 = 5.95mm
                                                    A tip, when using the calculator, don't round off until you have finished the calculation.
                                                    Cheap rulers and expensive micrometers usually have a table of equivalents (fraction/decimal inch) stamped onto them.
                                                    Stephen Benson
                                                      @stephenbenson75261
                                                      Nobody said it was hard to do I have a maths A level and I quite like doing trig when needed, but it is tedious to do every dimension when I would rather be cutting metal, but it seems I am alone it in this view. There are plenty of interesting projects with metric drawings out there so no problem for me however I did feel that Stuart Models were missing out but obviously I was wrong
                                                    Home Forums Stationary engines Topics
