Many thanks for the helpful replies. I’m sorry to be so long responding but thought I’d do so when I’d seen how things panned out.
I bought two replacement 1 x 1/16″ rings from Reeves which were much better than the original ones from Stuart – ‘shallower’ and much more flexible so far easier to spring over the piston without risk of breakage and prodoced much less friction against the cylinder walls while still giving a good seal.
I did chamfer the cylinder ends slightly and found that I could get the rings into the cylinder by pushing the piston hard down when friction against any protruding ring allowed me to ease the rigs in with a fingernal and aided by the chamfer.
Jason B: I take the point about not fitting rings, and the piston fit was good enough to run without them, but pride (as I said) dictated that I would at least attempt to get the engine completed ‘as spec’: in the event it actually ran very smoothly and evenly on air at 10 psi at less than 100 rpm – so I’m very gratified – and would expect to do better when run in a little as it’s still a little stiff. I’m actually surprised at how powerful and ‘torquey’ it is.
First steaming tonight as it seems more sensible to run in under hot conditions and I intend to steam it rather than air-drive. Then dismantle and the rather tedious business of painting, etc.
