Posted by Dr_GMJN on 18/08/2022 07:25:58:
Posted by noel shelley on 17/08/2022 21:36:12:
My limited german seems to indicate that the description of the" Deutschland" engines states that it had Quad expansion engines! Noel.
That’s how I understand it. Not much online about the engines, but the German Wikipedia seems to say they were 6 cylinder engines. The UK Wikipedia doesn’t mention them.
Is the additional small cylinder above the 10V the main cylinder, and the lower one a compound?
I am just looking at the plumbing on the main engine and trying to work out what they have done there to get four expansion stages and six cylinders. It looks like there are two HP cylinders sticking up above the cylinder heads of what would be a "normal" four-cylinder triple expansion engine with two LP cylinders. In this engine though, the HP pistons must run on extensions of the piston rods from the cylinders below them. But the two LP cylinders are not in the more usual position one at each end of the row, but rather are the two centre cylinders, according to the plumbing of the exhaust steam to the condensor. Never seen anything like it. Fascinating. Now that would be a model to build, if only I had another lifetime to complete it in!
Also quite intriguing is the mechanism that looks like a stack of washers on the main crankshaft output end, outboard of the barring gear. Looks like it is some kind of thrust block with a line of thrust bearings running in grooves in the shaft, to transfer the thrust load from the prop shaft to the hull without transfering any end-load to the engine bearings.
