On to the cross head last night, which is supplied as a brass stamping. It’s got a spigot, which is handy for holding it for initial work. First job was to face the end:
Drill and tap for the piston rod:
Then turn the O/D to within about 0.010” of finished:
Saw off the spigot:
Tighten onto the piston rod, mark it so it can be tightened to the same position in future. Then mount in the collet chuck and incrementally turn to size for the standard bore. A good tip to easily get fractions of a thou feed is to turn the compound slide to a slight angle to the bed, such that any turn on the crank translates to a much smaller amount of feed into the work:
The final feature is the connecting rod hole. I was concerned that due to any errors in size accumulating from my own work, combined with the un-toleranced drawings, I might end up with the piston crashing into the cylinder caps. I decided to temporarily assemble the cylinder, measure it’s internal bore length, and calculate the clearances at each end based on the actual crank throw.
Measured the throw by using the z-dro on the mill:
…and the bore length by measuring the piston displacement in a similar way:
From these figures I calculated that I needed 0.7mm clearance at each end of the bore. I made a 0.7mm thick washer and put it in the bottom of the cylinder:
Then, with the crank at the bottom of its stroke, marked the hole position:
Double-checked at the top of the stroke, spot-on:
So then dis-assembled, and mounted in the mill vice. Double-checked it was level, then marked, drilled and reamed the pin hole:
Next up is making the threaded pin. I think that’s the last bit of machining before test assembly.
