Guys – as you all probably know, there’s no defined method of directly lubricating the big-end bearing on the Stuart 10V.
I’m thinking of drilling a 1.5 mm hole from the curved base of the forked little end, all the way down to break through into the big end journal. I’d use a centre drill to form a v-shaped cup at the top. It’s not assembled yet, so would be a two minute job on the mill.
My thoughts are that I could then easily fill the connecting rod with oil, and it would lubricate the crank pin during a run.
Drawback is that any debris or wear particles from the crosshead/pin would also get directed straight down there.
Worth it? Not worth it? Any thoughts welcome. Thanks.
