Stretching a Wedding Ring
Home Forums General Questions Stretching a Wedding Ring
  • #92783
    Sub Mandrel
      @submandrel
      Any advice on this? It's a standard gent's ring so it's fairly wide and not a high carat (18?) alloy. I can easily make an expanding mandrel on a slow taper and squeeze it in a vice, but do I need to anneal teh ring and are there any gotchas?
      Sub Mandrel
        @submandrel
        #92784
          RDG do a ring stretcher, have a look at that to get some ideas how to make one, looks like it stretches the metal between two rollers. "Its under their new lines to RDG section"
          J
          #92786
          David Clark 13
            @davidclark13
            Hi There
            As its a gents ring, there is no point telling the bride to go on a diet.
            I would try a rod through the centre of the ring and roll the rod back and forth along a piece of hardwood or similar.
            This might stretch the ring sufficiently.
            regards David
            #92790
            David Littlewood
              @davidlittlewood51847
              Neil,
              This site shows the various tools which jewellers use for this, and a few useful comments about how much you can expand a ring without damage:
              No doubt a further search among jewellers' suppliers will turn up more.
              David
              #92797
              Sub Mandrel
                @submandrel
                Thanks for the ideas. I hadn't thought of rolling it. You've given me a few ideas, but can you anneal 'gold' (as in gold/copper alloy).
                Edit: it seems that for 9/10k gold (which I think it is) just red hot, then a rapid quench, otherwise it gets brittle.
                Another suggestion is put on a shallow taper and hit it with a hide mallet.
                Edited By Stub Mandrel on 19/06/2012 20:43:08
                #92801
                V8Eng
                  @v8eng
                  Hi.
                  If there are any colleges or craft centres teaching jewellery in your area they will have the equipment, and may be able to help.
                  Edited By V8Eng on 19/06/2012 21:19:21
                  #92802
                  Peter E
                    @petere
                    I have done precisely that some years ago. I used a slow taper Ring Mandrel like the round ring mandrel in David L´s post above.
                    Slip the ring on to the mandrel and using a plastic hammer (no metal at any cost) gently tap the ring on the mandrel.
                    The gold (typically 18 carat) is very soft so it will start to creep up the mandrel almost for every blow. You can actually feel it because the ring should be gently held tight to the mandrel while tapping. After a few blows you get the idea.
                    BR
                    /Peter
                    #92948
                    Sub Mandrel
                      @submandrel
                      For reasons of durability and impecunity when i got married, i thik its more likely to be 9 or 10K gold
                      Even so, I tried a nylon mallet on it, without annealing, over a bar that was a loose fit inside it. It's hard to be precise as it wasn#'t perfectly round, but I appear to have opened it up a little, but has helped a bit – say the difference betwen a force fit and a push fit
                      When I can find my elusive tub of easyflo flux, I will try annealing it and have nother go -I think I need at least 1/32", maybe more.
                      AndyP
                        @andyp13730
                        Only just seen this question and it is what I do !
                        Yes anneal, as described by John above, your usual flux will do fine. A good rule of thumb is to anneal for every two sizes growth of the ring, a UK size is roughly 1mm on circumference.
                        You should be able to take a plain 9k band up several sizes with a slow tapered mandrel and a rubber or nylon or hide hammer, since you don't need the whole range of sizes on the mandrel turning one becomes quick and easy, I have made several for specific jobs.
                        If it is a wide band, say 6mm or above, then keep reversing it on the mandrel so both sides end up the same size. I like to do this job in front of the customer and dispel the myth that what jewellers do is difficult and therefore expensive.
                        Take Care
                        Andy
                        #92952
                        Springbok
                          @springbok
                          Hi Stub yes listen to andy
                          Take it to you local jewell's shop they  will have all the kit to do this for you.  Items like this should not be messed around with if they have great sentimental value.   take it to the profesionals.
                          Bob
                          Edited By Springbok on 23/06/2012 03:19:38
