Hi Steve,
I suffered a problem with my first crankshaft for the Whittle V8, although I bent mine rather than it breaking. I am making mine form EN16 which seems to machine a little more forgiving than EN8. That said, I have roughed it out and left it to ‘relieve’ for a while. I found that the main problem was finishing the centre bearing as having finished the other cranks, the resulting lack of rigidity caused the centre bearing to ‘bounce’ against the tool.
I am now looking at a jig to finish all the bearing surfaces in the mill so that all of the crank si supported during the final finishing operations. I feel that machining in the lathe is doomed to problems.
There are many threads regarding this issue, here is one,
Google Whittle V8 and you will find many threads on this subject, there is also a yahoo group for this engine build.
PM me to collaborate on this, I amin Hampshire if you are local I would gladly meet up to discuss the build
regards
Graeme
