Strange metal
Strange metal
Home Forums Materials Strange metal
Viewing 21 posts - 1 through 21 (of 21 total)
  • #29623
        I made a little version of a traditional tool today, something that appears to have barely changed, if at all, since the mid 19th century or earlier, except it is now factory made rather than blacksmithed.
        I 'blacksmithed' mine as I wanted the same coarse appearance as a Victorian one.
        The metal I used was rather odd. It was heavy as steel and had a few (apparently) rust flecks, but looked slightly greyish. It was magnetic, jumping off my hand when I waved a small speaker magnet over it. it could have been stainless but it was as bendable as mild steel, easy to bend and re-bend and showed no work hardening even when beaten with an 'ammer, yet when hit with the hammer it took a lot of bashing to create flats on it. I was able to drill it 1/16" where it had been flattened with no sign of work hardening. I tried oil-blacking it and instead it went grey-green. One or two spots picked up some silver solder and flux off the bit of tile I heated it on, very unlike stainless.
        All in all i suppose it is stainless steel but it really doesn't behave much like one. It can't be a very hard aluminium alloy as it is so magnetic.
        Any ideas?
        #255145
        Peter Krogh
          @peterkrogh76576
          That sounds like old wrought iron. Pure iron with fine carbon that is mechanically included, not in chemical solution. I hard to find the stuff anymore! If you acid etch the rod, fairly heavily, and it shows a linear structure like lots of wires bundled, then you've got wrought iron.
          Pete
          #255148
          Vic
            @vic
            A spark test may indicate what it is. Sounds like it may be some kind of 400 series stainless.
            "400-series sparks are similar to 300-series sparks, but are slightly longer and have forks at the ends of the sparks"
            https://en.m.wikipedia.org/wiki/Spark_testing
            Edited By Vic on 10/09/2016 19:23:02
            #255152
            John Stevenson 1
              @johnstevenson1
              unobtainium or scrapbinium at a guess.
              #255157
              Bazyle
                @bazyle
                Perhaps nickel or a high nickel no chrome stainless as used for cutlery.
                #255166
                Rik Shaw
                  @rikshaw
                  Put us out of our misery Neil – what does your little tool do?
                  Rik
                  #255170
                  Roderick Jenkins
                    @roderickjenkins93242
                    Monel perhaps?
                    #255186
                    Speedy Builder5
                      @speedybuilder5
                      Monel:-
                      "Cold working can increase the magnetic properties while solution annealling can render the item non magnetic until it is cold worked again."
                      #255188
                      not done it yet
                        @notdoneityet
                        RJ may well be onthe right track. Green colour flagged it up for me as possibly a copper alloy.
                        According to goggle it should work harden – and its magnetic properties are interesting. Reaction with nitric acid is used to identify, or discern from
                         stainless steel or steel.
                        Edited By not done it yet on 11/09/2016 08:15:30
                        #255193
                        Gordon W
                          @gordonw
                          Grinder test– dullish red = wrought iron.
                          #255206
                            Spark test is either wrought iron or stainless, a single long-thin 'leaf' from each spark. If there's any final fork (400 series) it's barely there.
                            But not wrought iron, it would black and show colours when heated.
                            It must be a stainless, but one that is remarkably easy to work.
                            As for the mystery tool, come to MEX and see it at work
                            MW
                              @mw27036
                              Inconel or Nimonic?
                              Michael W
                              #255212
                              MW
                                @mw27036
                                Posted by John Stevenson on 10/09/2016 19:45:07:
                                I take it those ores are not very nice to work with? I can't seem to find unobtainium anywhere. Scrapbinium always get a poor surface finish and odd sizes. I prefer machining sponge, as it is the only material that can be both round and square with a bit of heft. wink 2
                                Michael W
                                #255227
                                  You know what i think this is?
                                  It looks just like Meccano axle, but 3/32" instead of 5/32". Which probably means it is a cheap stainless.
                                  Geoff Theasby
                                    @geofftheasby
                                    Have you checked it for radioactivity?
                                    Geoff
                                    #255265
                                    duncan webster 1
                                      @duncanwebster1
                                      Posted by Michael Walters on 11/09/2016 10:17:37:
                                      Michael W
                                      You should try quantonium, that can be round and square (or neither) at the same time
                                      #255273
                                      Raymond Anderson
                                        @raymondanderson34407
                                        If it is remarkably easy to work as Neil says then, it's certainly not Inconel or Nimonic. They are a lot of things but "easy " isn't one of them.smiley. I don't even know of a Stainless steel that is "remarkably easy to work " not even 303. Maybe even just a rubbish alloy used for parts of a toy. Don't suppose you will ever know for sure, need a lab for that.
                                        #255293
                                          Could it be a Maraging Steel, as used to make ultra-centrifuges and golf clubs?
                                          No doubt Neil would think of an ultra-centrifuge as being a "Traditional Tool". They were much used in the past to make ye olde enriched Uranium.
                                          mark costello 1
                                            @markcostello1
                                            North Korea for a source?
                                            #255307
                                            Vic
                                              @vic
                                              Maraging steel was also used in the grabs that failed during the partial raising of the Russian Submarine K-129 in the 1970's.
                                            Home Forums Materials Topics
