Posted by Rod Ashton on 21/12/2019 05:51:36:
This may seem a little obvious?? But just try leaving the caliper on a radiator or similar overnight. Go buy a new best quality battery and fit this after little dab of mild solvent on the terminals. – Remove the battery, after use on the chinese ones, if you have the patience?
I have six or seven cheapies that occasionally crash and you may be surprised how often they can revived by drying.
Worth a try, condensation causes electronics many problems, temporary and permanent. Cheap calipers are often associated with poor battery life, which is odd because measuring current they draw shows micro-amps. A decent battery should last a year or two.
One cause of poor life is the owner fitting the wrong battery, notably LR44 instead of SR44, or saving money with old-stock pound-shop specials, or fakes. However, I suspect the cells usually go flat because cheap calipers aren't sealed as well as their expensive brethren. Damp penetrates inside, and the resulting film of water holds dirt and tends to discharge the battery. Over time condensation will cause electrolytic corrosion, thoroughly upsetting the electronics as well.
I like Brian G's suggestion that the gauge is flipping mode, or that the read head is confused. Both could be due to damp induced corrosion / dirt. The problem may be too small to detect with the naked eye. Drying out may fix it, but removing corrosion may require a deep clean of the entire unit. Pay special attention to exposed areas like the head and to less obvious areas like the switch contacts and circuit traces. Due to the construction, it may not be possible to get inside without breaking something – these are not designed to be maintenance friendly.
Is it worth the bother? I suggest it's time to take advantage of the very best feature of cheap Chinese Tools, which is they are cheap. This one is well out of warranty. Replace it. If there's any suspicion a slightly damp workshop is the cause, keep the new caliper in a sealed box with a silicone absorber.
