Straightening stainless steel rod/wire
Home Forums General Questions Straightening stainless steel rod/wire
Viewing 6 posts - 26 through 31 (of 31 total)
  • #205430
    Ian S C
      @iansc
      It is some times possible to straighten wire by fixing one end to something solid, and a weight or something to tension the wire, then attach the wires from a reasonably substantial power supply to each end of the wire to be straightened and let it heat up to red , then switch off the power and let it cool, the wire should be straight. I don't know if it works with stainless steel. I don't know what weight you would need, I'v got 6 ammo boxes with 50+ lb of lead in each of them, that's what I would use, just keep hooking them on until it "looks" right.
      You could make frames for light shades, or similar sort of things.
      Ian S C
      Bubble
        @bubble
        Posted by Bubble on 18/08/2015 16:14:29:
        Hello Mark P
        Of course, eye protection, gloves etc.
        Jim Tut, Tut, never use gloves on lathes, drills, rotating machinery, surprise
        Hello all
        "Never" And there's me thinking that people on here use common sense.
        Here's a link to a sensible man **LINK**
        Jim
        #205476
          I'd love to know hoe on earth he knows he had nothing that would have been a close call if he was wearing gloves?
          One of my nephews has worked on ambulances with the paramedics and his least-favourite injury is degloving, often caused by a real glove being drawn into rotating machinery.
          Google it if you aren't squeamish.
          These incidents are not rare as he has seen a number of them.
          But it's your own fingers….
          Ian S C
            @iansc
            I think he's just selling gloves.
            Ian S C
            #205573
            Cornish Jack
              @cornishjack
              Obviously a contentious subject but 'horses for courses', maybe.
              Along the lines of his argument pro gloves, I spent many years operating helicopter winches and would NEVER consider doing wothout the supplied armoured leather gloves. The cables could 'birdcage' and separate without warning and a hydraulically powered loose strand through the palm of the hand could make the eyes water somewhat. Perhaps not directly applicable to workshop machinery but, on a personal basis, I'm MUCH happier with the commonsense argument than the ' it says in the book' approach.
              rgds
              Bill
              #205583
              Gordon W
                @gordonw
                We've had this gloves/no gloves before. I never wear gloves unless I have to, esp. for things like turning, It's my choice. Never wear rings or watches either. But I do use heavy gloves for handling wire rope etc. , sadly I don't have armoured ones.
