Stirling hot air engine plans
Home Forums I/C Engines Stirling hot air engine plans
  • #86027
    Richard Clark 1
      @richardclark1
      Hi,
      Does anyone know where I can get plans to build a stirling hot air engine fan the type that sits on top of a wood burning stove.
      I am not sure where to look for such plans but would like to build a hot air engine fan. I believe there was a fan called moriya by Dr Senft.
      If anyone has any info or advice I would be grateful.
      Thanks in advance guys.
      Richard..
      Richard Clark 1
        @richardclark1
        #86031
        David Clark 13
          @davidclark13
          Hi There
          There was a plan by Dr Senft for a hot air fan in Model Engineer probably late 60s, 1970s or early 80s.
          I would think early to mid 70s.
          Check an online index.
          regards David
          Edited By David Clark 1 on 27/02/2012 21:59:19
          #86043
          Geoff K
            @geoffk
            Jerry Howell in the US has some good plans for this type. There are no castings involved and his detailed instructions on making the components are second to none.
            Geoff
            #86140
            Ian S C
              @iansc
              Stove topOne of two stove top Stirling Engines I havedesigned an built, the cylindrical column is the displacer cylinder, made from a bit of extension tube from a vacuum cleaner. Ian S C
              #86158
              steamdave
                @steamdave
                Clarence Myers has a design for a stove top fan. Not sure whether he would sell you the drawings without the castings, though.
                http://myersengines.com/_x/
                The Emerald Isle
                #86267
                Richard Clark 1
                  @richardclark1
                  Hi everybody,
                  Thanks for the info on the stirling engines.
                  Great picture Ian thats the sort of thing I was looking for I have tried to find the Dr Senft Moriya plans for the same looking engine as you have Ian.
                  Does anyone know if there are plans to build a stove top fan in the Stirling Hot Air Engine book by Roy Darlington, not sure if that book has any plans that I would be looking for ?
                  Thanks in advance Guys.
                  #87662
                  Howard Lyne
                    @howardlyne10956
                    Hi Richard
                    I've come to this thread a bit late I'm afraid, but take a look at http://www.gyroscopes.co.uk/images/stirlingfan/stirlingfandiagram.gif
                    I too intend to build a fan for a stove and came across this image some while ago. While not exactly a plan, it comes pretty close. The gyroscopes.co.uk site will also sell you a ready-made one and there are a lot of other fascinating bits and pieces on there too.
                  Home Forums I/C Engines Topics
