It took me 3 goes to get it right, don't use aluminium displacers unless you want to see a melt down, also less efficient than stainless steel, or mild steel (it corrodes). the end of the stainless tube is atached by TIG welding, try and keep to about 0,010" or a little more, 0.007 is possible, but getting difficult.
I have used copper gaskets, these should be annealed, for sealing, but tend to use metal to metal joints see the hot cap photo among the groupe of batter cases, it is bolted to the motor with 4 1/8 x 40 Whitworth bolts.
Ian S C
Edited By Ian S C on 30/01/2020 12:15:04
