Stirling Engines
Stirling Engines
Home Forums Stationary engines Stirling Engines
  • #96238
    David Nunes
      @davidnunes86795
      Over the past several years I have built and exhibited many Stirling engines, some of which use a diaphragm instead of a power piston. I usually use a latex glove to make the diaphragm but I find that they tend to biodegrade in a very short period, very often as quickly as 5 months. Can anyone suggest a more likely source of less biodegradable material that I might try. Condoms and ballons have been suggested but not yet tried.
      David Nunes
        @davidnunes86795
        Diaphragm driven Stirling Engines
        #96241
        MICHAEL WILLIAMS
          @michaelwilliams41215
          Kevlar sheet .
          #96313
          Ian S C
            @iansc
            A rubber or synthetic with a fabric reinforcing layer (maybe Kevlar) would be ideal, specially if concentric corrigations could be included. About 2 yrs ago, I was thinking of making up a mold to make some experimental diaphragms. Up to that time I had been making molds for rubber components for vintage millitary vehicles, mainly Willys Jeeps. There are quite a number of different rubbers for different uses. I lost my molds in Christchurch's earthquake, I don't know even now if they have been salvaged, about 6 or8 molds at a value of over $NZ1000 if they had been professionally made. Ian S C
            #97219
            dcosta
              @dcosta
              Hello All!
              Just for curiosity I invite you to observe two Stirling engines. Both are crude, made with simple materials, but functional. One even generates 12V, 4W.
              Here **LINK** and here **LINK**
              Best regards
              Dias Costa
              Edited By dcosta on 27/08/2012 16:01:32
              #97233
              Skarven
                @skarven
                I have no experience with stirling engines, but I think the efficiency seems to be on the low side. An input of about 1000 to 2000 watts gas flame heating for a battery charging of 2W, then increased to 4W by improvements.
                Is this typical for stirling engines?
                #97240
                Sub Mandrel
                  @submandrel
                  This suggests stirling engineare more efficient than internal combustion, with achieveable efficiencies of 15-30%.
                  Certainly there are many practical applications on record.
                  Edited By Stub Mandrel on 27/08/2012 20:20:38
                  #97243
                  Sub Mandrel
                    @submandrel
                    Also:
                    "The MOD II project in 1986 produced one of the most efficient automotive engines ever made. The engine reached a peak thermal efficiency of 38.5%, compared to a modern spark-ignition gasoline engine, which has a peak efficiency of 20-25%."
                    Much food for thought – why do model stirling engine have ssuch relatively low efficiencies – or is it lust that they are too small?
                    MICHAEL WILLIAMS
                      Primarily because most small hot air engines are not pressurised .
                      For any hot air engine to produce higher efficiencies and a high power/weight ratio it must work at the same order of cycle pressures as an IC engine . This means a high average pressure and rapid input/output of heat to obtain large cyclic pressure variations .
                      #97274
                      Ian S C
                        @iansc
                        Stirling engines can be made in model form with a reasonable power to weight ratio, as shown by a number of motors made and flown in model aeroplanes, a case of suitable materials, and good design work, I think all the ones I know of are unpressurised. Ian S C
                      Home Forums Stationary engines Topics
