Stewart Hart’s Vertical Mill Engine
Home Forums Model Engineer. Stewart Hart’s Vertical Mill Engine
Viewing 25 posts - 1 through 25 (of 25 total)
  • #176486
    SarahJ
      @sarahj
      Hi,
      I would like to make a start on Stewart Hart's Vertical Mill Engine.
      In the drawing of the cylinder, there are four M3 tapped holes in each end for the cylinder covers. The drawing doesn't show how deep to drill/tap into the cylinder, I was going to drill the holes 8mm deep and tap into that by 6mm. Does that sound okay?
      One other point I was wondering about was the 3mm dia hole into each end of the cylinder for the two steam passages. This leaves a wall thickness of 1mm between the cylinder wall and the steam passage. I could reposition the hole slightly to give a slightly thicker wall thickness of 1.4mm. I was just concerned about when drilling the hole the drill bit wandering. Any thoughts on this?
      Many thanks,
      Sarah
      SarahJ
        @sarahj
        #176491
          Welcome to the forum Sarah
          I'm sure Stew himself will be along at some time but those depths sound fine to me.
          Again the drilled passages could be moved if you wished, I think as shown the hole comes mid way between the cylinder bore and the flat surface the valve chest mounts to so just watch the outside. A good sharp drill should not wander too much it helps to retract the drill quite often to clear any swarf and also a little lubrication in the way of parafin or WD40 will help too.
          J
          Edited By JasonB on 18/01/2015 17:54:01
          #176499
          Stewart Hart
            @stewarthart90345
            Hi Sarah
            Pleases to her that you've made a start on the vertical, the depths you've suggested will be fine, sorry I missed the depth off the drawing. The passage is a bit close if you want to give yourself a bit more space by all means move it over a bit and it wont arm if you drill it 2.5mm, and follow Jason's good advice.
            I hope you enjoy the build.
            Stew
            #176500
            SarahJ
              @sarahj
              Hi Jason and Stewart,
              Thanks for your replies. Another question for you if that's okay.
              When drilling/tapping the eight M2 holes in the cylinder for the Valve Chest, I calculate that there is 5.86mm depth of material for the tapped holes. What depth would be suitable for drilling and tapping.
              Sarah
              #176503
                A good rule of thumb is that you want 1.5times the dia of thread in the part so for a M2 thread you want 3mm of thread. Now its almost impossible to thread right to the end of your hole so I would say drill 4.5mm deep and tap until you feel the tap won,t turn any more.
                One thing I do with a lot of my small taps is grind off the pointed end as that usually allows you to get a bit deeper into a blind hole, not enough to cut into the teeth but just enough to remove the pointed end
                #176590
                SarahJ
                  @sarahj
                  Hi Jason,
                  Thanks for your help, I'll mark up the drawing with the depths I need.
                  Many thanks,
                  Sarah
                  #183912
                  Jmccrack
                    @jmccrack
                    Stewart. I am looking for the material list for this project. Has it been published yet?
                    #183913
                    Stewart Hart
                      @stewarthart90345
                      Hi its on the home page towards the bottom on the right or click below
                      Materials List
                      Stew
                      Edited By JasonB on 20/03/2015 15:20:50
                      #244193
                      Mad muppet
                        @madmuppet
                        Good morning All.
                        Help please How can I obtain a set of drawings for the cross vertical engine.
                        Regards Mad Muppet
                        #244195
                          If you ask Stew nicely he may sort you out.
                          #244203
                          Eric Cox
                            @ericcox50497
                            Sarah, for material you will find 5" pipe for the flywheel here
                            .ebay.co.uk/itm/Mild-Steel-Pipe-127mm-5-x-3mm-450mm-long-Chimney-Round-Tube-/291164852350?pt=LH_DefaultDomain_3&hash=item43cac7107e
                            and aluminium plate here
                            ebay.co.uk/itm/Aluminium-Flat-Bar-Plate-width-from-120mm-to-250mm-many-thicknesses-and-lengths-/151080276666?pt=UK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET&var=450190730544&hash=item232d1612ba
                            usual disclaimer
                            #244357
                            Mike Bondarczuk
                              @mikebondarczuk27171
                              Hi Sarah,
                              I am just putting the finishing touches to the Stewart Hart Horizontal engine and will be starting the vertical engine build once completed.
                              I hope that you will be posting a build log so that I can follow your progress as well as any hints, tips or get-me-out-of-jail situations you come across.
                              I have posted a short video of my engine on the Model Engine Maker forum and have entered it into the built from plans section, so you are welcome to have a look.
                              I may also post it on this site if I can find a way of attaching a YouTube video, and a full build log will follow shortly together with the cosmetic changes I made to the original design.
                              #244363
                                Mike have a look part way down this page on how to post youtube video. Or ask me to do it
                                #526930
                                Dullnote
                                  @dullnote
                                  Hi hope this works, first run for the engine today, not completed but enough to get it alaive
                                  #526931
                                  Dullnote
                                    @dullnote
                                    #526936
                                    Steviegtr
                                      @steviegtr
                                      Posted by Dullnote on 13/02/2021 16:45:35:
                                      JUST TRIED TO VIEW & IT SAYS THE VIDEO IS PRIVATE.
                                      Steve.
                                      #526937
                                      Dullnote
                                        @dullnote
                                        I will have a look though it was anyone who had link
                                        #526938
                                        Dullnote
                                          @dullnote
                                          Changes to unlisted, try now
                                          #526939
                                          Steviegtr
                                            @steviegtr
                                            Yes but that is not a link. It is just the address to put in the search bar. I always set my videos to anyone can view.
                                            Steve.
                                            Edited By Steviegtr on 13/02/2021 16:56:36
                                            #526941
                                            Steviegtr
                                              @steviegtr
                                              No still not able to view.
                                              Steve.
                                              #526945
                                              duncan webster 1
                                                @duncanwebster1
                                                I can't see it either
                                                #542194
                                                David Wallbank
                                                  @davidwallbank94791
                                                  Regarding Stewarts Hart's "True Vertical Mill Engine" is possible to get drawings ? I managed to find a link for the materials list but not constructions drawings. I have not found a way to ask Stewart directly.
                                                  Thanks, David.
                                                  #542260
                                                  Jim Nic
                                                    @jimnic
                                                    David
                                                    As a fan of Stewart's with 4 of his designs built I have always found him to be very generous and accomodating. Although he doesn't post on here much these days I'm sure he won't mind me telling you how to get in touch with him. If you send him a Personal Message and ask him to send you a set of drawings I am sure he will oblige.
                                                    To send a PM Click on "Inbox" at the top of the homepage, Click on "Compose new message", address it to Stewart Hart and ask away.
                                                    Jim
                                                    #542269
                                                    Stewart Hart
                                                      @stewarthart90345
                                                      Hi David
                                                      I'm sneakily watching coolas Jim said just send me a PM with your email address
                                                      Stew
                                                    Home Forums Model Engineer. Topics
