Stepper power for autofeed on lathe
Viewing 25 posts - 1 through 25 (of 48 total)
  • #375255
    Phil Grant
      @philgrant54580
      Hi,
      Been having a read through the forum as research for adding a stepper motor to my Warco super mini lathe autofeed.
      It looks like the kit Myfordby uses in his youtube video is favourite at the moment.
      I've designed and made a bracket to replace the gears at the end of the lathe using a Nema 23 stepper motor and I was wondering if anyone has a suggestion as to the power needed for the stepper, is 3Nm OK or too much.
      I've fettled the leadscrew mounts and it turns freely by hand with no load but not sure what sort of torque will be required when cutting.
      I'm using a stepper motor with a simple speed control at first but looking to add an arduino into the mix later for thread cutting and maybe adding another stepper to the cross feed later to dabble in a CNC conversion maybe……
      Thanks for any help.
      Phil Grant
        @philgrant54580
        #375264
        not done it yet
          @notdoneityet
          Feed rate for surface cutting is one thing, but advancing 2.5mm per spindle revolution may need rather more power, I would guess? Not thought whether 3Nm is enough or too much.
          #375271
          John Haine
            @johnhaine32865
            The Z feed for my Super7 CNC conversion uses a type AC5707645251 size 23 stepper motor that came from Arc Euro Trade (I think they no longer stock these). Googling it says that it's rated torque is 180Ncm – what a ragbag of units! But that's 1.8 Nm. There's a 2:1 toothed belt reduction between motor and leadscrew. I have never had a problem with inadequate torque either surfacing or screwcutting. The leadscrew pitch is 1/8" so slightly larger than yours. I can't see why more torque would be a problem? The driver is the ubiquitous 2m541 type, also from Arc, supply ~40V and probably running peak current of 2.5A or so.
            #375282
            Phil Grant
              @philgrant54580
              Posted by John Haine on 09/10/2018 22:22:17:
              Thanks for the info.
              #376919
              Phil Grant
                @philgrant54580
                Hi,
                Went for one of these in the end **LINK** with a DM542T controller and 24V power supply direct from stepperonline delivered from the UK.
                Quite reasonably priced and delivered in a few days.
                Got it all on the bench working with an Arduino using Accelstepper library.
                Got to get some sort of user interface together then attach it to the lathe.
                #376923
                Muzzer
                  @muzzer
                  Most of the hobby people just go on the basis of what others have found to work. The reason being that it's not easy to measure or estimate the required torque and speed extremes. And even then, to describe a stepper as "1.8Nm" is often unhelpful. I doubt if many of them could actually muster that level of torque to begin with – and it falls off very rapidly with speed.
                  You'll notice that the Chinese outfit you used also sell clones of the Leadshine "integrated easy servo" stepper motors. These combine the stepper driver module into the motor, along with an encoder on the motor shaft. This requires a lot less messing about to connect up the driver (just provide the step/dir signals and DC power) and being closed loop, it won't suffer from lost steps and can recover from a temporary overload. That's many of the advantages of a true servo with the cost of a stepper – and no external amp / driver, cleaner wiring etc. That additional level of control robustness means you don't need such a large margin of safety on the torque to guard against loss of position.
                  Incidentally, as the torque from a stepper motor drops off roughly proportional to speed, there is usually no advantage in creating a step-down reduction by using gears or pulleys. The effect of such a reduction is to make the motor run at twice the speed – and about half the torque. The net result is simply a reduction in the maximum speed of the output shaft, which is a problem for stepper motors to begin with. You are generally better off driving the leadscrews directly with steppers.
                  Murray
                  #376941
                  Martin Connelly
                    @martinconnelly55370
                    I use small Leadshine hybrids on my lathe. I do have a timing belt drive though because I spin the nut to push and pull the lead screw attached to the saddle. The driven pulley is threaded onto a bush that fits into a pair of flanged bearings and allows backlash elimination by squeezing down on the two bearings that sandwich a fixed plate between them. The reason for this system is that it allows modification with minimal change on the lathe so it can be reverted to manual if required. The downside is that you need to allow for a leadscrew sticking out of the tailstock end.
                    If you are not after rapid motions a large motor is overkill. Hobby use is not usually looking to shave seconds off a job.
                    Martin C
                    #376942
                      Posted by Muzzer on 21/10/2018 11:36:30:
                      Murray
                      I love this forum! Thanks to Murray, I realised my understanding of steppers was adrift re their relationship to gearing and did some emergency googling.
                      I found this graph with description here which is illustrative as an example.
                      Very educational.
                      Ta
                      Martin Connelly
                        I don't think that graph applies to hybrid stepper systems. They are supposed to have superior dynamic torque compared to standard stepper motors.
                        Martin C
                        Edited By Martin Connelly on 21/10/2018 13:24:50
                        #376949
                        Martin Connelly
                          This is how I have my lathe set up for the Z axis drive. The leadscrew is 16mm if you are wondering about sizes.
                          The leadscrew connects to a plain rod to push/pull the carriage. This type of setup also allows for testing the drive torque with minimal changes to the lathe if you are experimenting with different systems.
                          Martin C
                          #377343
                          Phil Grant
                            @philgrant54580
                            Getting to grips with the Arduino controlling the stepper motor, waiting for some parts to mount it on the lathe but in the meantime I designed and 3D printed an end cover with cable management to fit with the flexible plastic tubing I have for protecting the cables.
                            If anyone is interested I can post the STL file on Thingiverse.
                            #431024
                            Phil Grant
                              @philgrant54580
                              Just an update on my powered feed project, I came across this video on Youtube
                              I bought the TI LaunchPad board and designed my own, through hole, PCB for the interface and am just waiting for the PCBs to arrive.
                              Edited By Phil Grant on 29/09/2019 11:17:19
                              #431172
                              Brian Oldford
                                @brianoldford70365
                                Posted by Phil Grant on 29/09/2019 11:16:36:
                                That's the system I'm currently in the process of fitting to my S7. I doing the mechanicals at present.
                                I'm hoping a **LINK** driving through a pair of 1:1 skew gears will be sufficiently powerful.
                                In his latest video James says his interface boards will be available fairly soon. I'm waiting to see what the price is before deciding to buy one from him or to do what you've done by rolling your own.
                                #431175
                                Phil Grant
                                  @philgrant54580
                                  I did my own PCBs as they are very cheap to get made in China and I don't want the hassle of doing surface mount, the boards will probably be cheaper than just the postage to cover the boards from the states.
                                  I used a 2.8Nm NMEA23 stepper mounted direct to the leadscrew on my mini WARCO lathe and although I've not done any threads yet is works fine as a power feed driven from an Arduino.
                                  #431199
                                  Brian Oldford
                                    @brianoldford70365
                                    Posted by Phil Grant on 30/09/2019 13:06:28:
                                    How many did you have made? What sort of price were they?
                                    #431232
                                    Phil Grant
                                      @philgrant54580
                                      Around £10 ish for 10 off.
                                      Ignore the strange blocks, there were no shapes stored against these parts so Fusion adds an appropriately sized box.
                                      PCB
                                      Edited By Phil Grant on 30/09/2019 19:09:45
                                      Edited By Phil Grant on 30/09/2019 19:10:48
                                      #431260
                                      Phil Grant
                                        @philgrant54580
                                        Just noticed I published an image of the board showing two power LEDs, these are not on the PCBs I ordered and am waiting for, this would be a version 2 if required.
                                        #431262
                                        Phil Grant
                                          @philgrant54580
                                          Just printed a bracket to mount the optical encoder onto the lathe
                                          #431407
                                          Phil Grant
                                            @philgrant54580
                                            PCBs
                                            #433997
                                            Phil Grant
                                              @philgrant54580
                                              The final PCBs arrived yesterday for the Electronic leadscrew project from Clough42..
                                              t powered up and worked fine, There are spaces for the eeprom and two power LEDs, 5V and 3.3V but I haven't populated them as it will be inside a box and not visible. I also changed the power socket to a surface mount one because it sits overs some header pins on the host board.
                                              Edited By Phil Grant on 20/10/2019 08:36:14
                                              Edited By Phil Grant on 20/10/2019 09:20:01
                                              #433999
                                                Phil
                                                I would be interested to see the images … but your posts are currently displaying empty frames.
                                                Grateful if you could try again
                                                Phil Grant
                                                  @philgrant54580
                                                  Does it show now? I forgot to change the dropbox link to display the image, sorry
                                                  #434010
                                                    Posted by Phil Grant on 20/10/2019 09:21:07:
                                                    Still not showing for me, Phil [on iPad]
                                                    … perhaps someone else could check
                                                    Thanks for trying yes
                                                    Phil Grant
                                                      @philgrant54580
                                                      Another go for the images.
