Stepper Motors
Stepper Motors
Home Forums Electronics in the Workshop Stepper Motors
Viewing 15 posts - 26 through 40 (of 40 total)
  • #175405
    jason udall
      @jasonudall57142
      This is not going to include any functional printed parts..
      Ball screws and recirculating linear slides..
      Think machine tool build
      But at 400mm cube (600 mm throw)..it might need a bit better motions eh?
      Plan is to run build area at upto 200C…that should improve lamination and reduce
      shrinkage skew. ..
      Edited By jason udall on 09/01/2015 21:07:59
        Posted by Neil Wyatt on 09/01/2015 20:34:45:
        > For my pennance, here is a link to one implementation of an Allegro device.
        £18 to cover conversion from SMT to DIL (retrograde step if you ask me) and add four resistors and a capacitor!
        Neil,
        " … one implementation … "
        I was citing it as an example, not doing a Value for Money analysis.
          Having bought five of those stepper boards I'm still to try one out. Realised I have no idea of he pinout… so did a bit of digging.
          They are clones of the Pololou board, and if you want to know the pinouts and much more look HERE
          jason udall
            @jasonudall57142
            Neil..and others. .
            Have a care when setting up some of the polou clones. .for example stepstick..the voltage vs coil current is not always the same..( reference resistor differs thus current/voltage ratio)…definitely get the right procedure for the boards YOU have…
            #177115
              Thanks Jason,
              Last night I found this page:
              It points out that the standard board uses a resistor that give a maximum current of over 4A!
              Mine is the same as the one in the picture (note the ghastly new coding system where 30C means 20K!) I'll follow the advice in the 'upgrade' section and swap in a 100K resistor, as my stepper is rated at 24V/800mA.
              Les Jones 1
                @lesjones1
                Hi Neil,
                Thanks for pointing out the new SMD resistor coding system. This is the first I have heard about it so I "Googled" it. I assume you meant to say 30C means 30K (Or 20C mens 20K)
                Les.
                #177123
                Russell Eberhardt
                  @russelleberhardt48058
                  Posted by jason udall on 09/01/2015 21:02:35:
                  shrinkage skew. ..
                  Sounds as if this should make an interesting article or build thread in the 3D printing section.
                  Russell.
                  #177138
                    Hi Les,
                    No the new 1% system is really odd. 30 stands for 200(!) and C stands for x 100 so 30C means 20K.
                    Essentially you will have to keep the chart handy and perhaps memorise a few common ones.
                    Les Jones 1
                      @lesjones1
                      Hi Neil,
                      I should have read the document I found properly rather than just skimming through it. Although it seems illogical it does reduce the number of characters reqired to identify the ever smaller components.
                      Les.
                      #177155
                        Who would have though you would need a loupe to do electronics, thirty years ago!
                        Muzzer
                          @muzzer
                          I see that NYC CNC has posted a set of videos recently covering the use of Arduinos with the GRBL "shield"(yuk) to make a simple CNC machine. Well presented intro and real world example. Possibly quite timely for this thread.
                          Murray
                          #177191
                          jason udall
                            @jasonudall57142
                            Who would have though you would need a loupe. ..not just me then…
                            Didn’t expect to need the dissecting ‘scope for electronics
                            #177192
                            jason udall
                              @jasonudall57142
                              Russell. .that thought has crossed my mind..but this is for a customer. .though with permission maybe.
                              #177200
                                "Shield" is bad. Beaglebone has 'capes'. Raspberry Pi has 'Hats' but the RPi based Pi-top goes one better and has 'Pi-Top hats'.
                                In my day you got an 'expansion board' and were happy!
                                jason udall
                                  @jasonudall57142
                                  Shield..pun ..board usually sits above arduino…but is specifically shielding the arduino from “real world signals and levels”…
                                  The other names are just continuing the ( week) joke.
                                  Ignor it . It might go away
