I've spent the last few months putting a laser cnc together and have just got to the stage of testing the stepper motors.
The Y axis (Nema 17, 2 amp) one works perfectly – smooth, quiet and cool – so at least I know I can wire one up correctly.
The Z axis (Nema 23, 3 amp) one is smooth and quiet, but gets pretty hot – too hot to comfortably touch after about ten minutes. If I set the current lower then it doesn't rotate.
The X axis motor (Nema 23, 2.3 amp series, or 4.2 amp parallel) is very noisy, especially when starting and stopping, and it also seems to randomly make its own mind up on which direction it goes in. I have tried every current setting, and, since this one has 8 wires, I have also tried both series and parallel wiring configurations.
The motor drivers are DM542's and the controller is a Ruida 6445G. The testing so far has been with the arrow keys on the controller (not ready for g-code yet, and the laser tube isn't installed).
The Z axis motor is not going to be used much, unlike a cnc router or mill its only used to set the bed height at the start of a job, but it will be sitting there getting hot because of the holding torque, so I'd like to sort it out if possible.
The X axis motor is more of a problem as it will be constantly on the move, so it would be nice if it was reasonably quiet, and important that it moves in the direction its told to!
Any ideas?
