Hello all,
I have been working on a CNC conversion for my Bridgeport Mill. The original idea was to just motorise the X axis and a 6” dia HV table so that the machine could cut gears whilst I got on with more mundane tasks.
The rotary table was done first with a NEMA 23 motor from Arc Euro and a cheap single axis TB6560 driver. BTW, I have found this driver absolutely fine for the NEMA 23 motor, despite hearing and reading many things to the contrary.
The X axis was the next to be undertaken using a Nema 42 motor and a DM2722A driver from Longs motors, again based in China. This was completed successfully and runs very well when driven with Mach3. For the gear cutting, I can live with the backlash on the X axis, but there are hopefully some ball-screws being brought into the UK for me next month.
Work has progressed on the Y axis conversion and I was all set last Friday to run both axis at once and cut a circle, albeit in fresh air. Unfortunately, the Y axis driver has shown an alarm from initial power up and refuses to work. I swapped the drivers over so that the “older” driver drove the Y axis and the motor was fine.
I have contacted the suppliers in China and they pretty much say that I must return the driver to them for testing, despite all my explanations and photos. I feel that they have me over a barrel really and the cost of posting to China and accompanying delays, doesn’t help my situation.
Is it going to be a practical proposition to have this driver repaired and is there anyone on this forum that could undertake such a task? I feel so frustrated because I came so close, even though I can still cut the gears ok.
Best regards,
Steve.
Edited By Steamer1915 on 27/10/2014 20:15:23
Edited By Steamer1915 on 27/10/2014 20:17:42
