Thanks for both replies, The loco is a 2.5 inch Southern Maid (LBSC) The eccentric straps are marked (punched) with pips 1 to 4, When I took a photo before dis- assembly these pips were at the top of the loco (looking down) that is (I think) how I received the loco, but after dis assembly I notice that one of the actual eccentrics on the axle was punched with four pips ( which now meant that pips appeared underneath) after I put it back together!. If I understand "Workshop Pete" I think you are saying undo the two wrong eccentric (straps)and reverse these on the axle?
