Posted by Muzzer on 15/08/2014 22:34:19:
A variable voltage DC supply is not the best way of driving a brushed motor, far better for your purpose in this case is a variable pulse width controller. eBay has lots of them
The LM2596 actually is a PWM buck converter, so it wouldn't actually be a bad choice for controlling a small motor. The switching frequency is 150kHz (hence the tiny inductor which is the small grey cube). The main issue here is that the max output of 3A sounds rather puny.
On the other hand, the 8A units are rather crude in comparison – they don't even have any form of current limiting or voltage regulation. The lack of current limiting may not matter much if you can avoid wiring shorts and the speed regulation will be pretty poor when driving a brushed motor anyway, even if you had a regulated voltage. As suggested, you'd want to fit a flywheel diode for driving a motor with one of these. Even better get a proper motor speed controller….
Murray
Murray
The first paragraph of your post is a 'quote' from my earlier one. However what I should have said that for motor control a 'PWM Motor Speed Controller' was best.
A PWM motor speed controller is a different animal to the item you linked to, and to some of the others mentioned in on posts on this topic.
Pulse width modulated circuits are used for numerous purposes, DC power supplies and motor speed regulation are just two of them. The various step up, step down regulators on eBay are designed to produce a regulated DC voltage which is definitely not the optimum of driving a DC motor (maybe OK if its fixed speed and load).
Proper PWM motor speed controllers, apart from having much better speed control will also drive the motor more efficiently and allow it to produce greater torque at a lower speed, they will also incorporate protection circuitry so should not need any additional diodes.
Ian P
As has been mentioned, an electric screwdriver is not really suitable for continuous running although Mick has not given many details about what his machine is going to be used for, if its going to be filing Balsa wood or for watch making it will probably be fine.
