Steel…what kind?…
Steel…what kind?…
Home Forums Materials Steel…what kind?…
  • #226781
    lancelot
      @lancelot
      Hi folks…working on my Corliss build and making fork ends for the occilating drive rods…I managed to scrounge a section of steel from an engineering shop and went ahead to make them…I was soon to discover easier said than done…this stuff was like armour plate…very hard to get a good finish on cut …tended to tear rather than cut and difficult to file…also gave off streams of small yellowish white tiny sparks on touchíng the buff wheel…any thoughs on what this material could be…
      Lancelot.
      lancelot
        @lancelot
        #226787
        John Stevenson 1
          @johnstevenson1
          Useless
          #226793
          Chris Evans 6
            @chrisevans6
            Sounds like very high carbon. Bin it and start again with a known quantity.
            #226794
            Rik Shaw
              @rikshaw
              What size size/shape of section did you scrounge? Would you say it was heavier or lighter than mild steel or about the same? Is it magnetic or not?
              Rik
              #226799
              Hollowpoint
                @hollowpoint
                What you have described sounds just like titanium! You can test it if you have some swarf from the material. Gather a small pinch and light it with a blowtorch. If it bursts into bright white sparks it's titanium.
              Home Forums Materials Topics
