Would anyone know what type of steel is typically used for the shaft/piston rod of oil hydraulic cylinders such as used on earth moving machinery?
I need to re-make the spindle for my CNC lathe – the previous attempt used a piece from a caterpillar side shaft and was successful, but the oil seal mechanism I used in the headstock was not.. So a new headstock setup with different bearing oil drainage means a longer spindle is needed.
I cannot find another CAT drive shaft, but can get lots of hydraulic cylinder shafting from the local mining equipment repair shop.
I have cut a 200mm length from a 60mm OD shaft – it has (had) a very thick hard chrome layer, which I took off with a carbide tip in the lathe. Under the chrome, the steel machines very nicely, leaves a smooth, shiny finish, and the swarf comes off blue/straw coloured – either a long curly string at 1000RPM with 'low' feed rate, or short curly chips at high feed rates with the tip chipbreaker doing its job- the high feed rate also creates fine sparks at the cutting edge.
I used a 1mm wide carborundum cutting disc to cut a groove around the shaft periphery in order to get through the chrome before cutting the shaft off in the bandsaw – saw blade in that groove.The disc raised fine very bright white sparks once past the chrome layer.
Any Ideas on the steel type?
Joe
