Steel stock for newbie ???
Home Forums Beginners questions Steel stock for newbie ???
Viewing 25 posts - 1 through 25 (of 29 total)
  • #495153
    Ian Richards 4
      @ianrichards4
      Appologies for such a basic question, but we all had to start somewhere !
      I know my question is rather vague, but …
      My interest is in steam engines, both full size and model and I'll probably be working with Imperial measurements.
      I've looked without success for advice on what sort of steel stock I should have in my workshop.
      A little clarification what types and suggested dimensions would be really helpful.
      Rather than buy the odd piece when needed, it would be great to have an assortment available and more cost effective too.
      TIA
      Ian
      Edited By Ian Richards 4 on 10/09/2020 20:24:35
      Ian Richards 4
        @ianrichards4
        #495154
          An idea of the type of work you intend to undertake may help as someone building small aero engines will need different materials to someone making a 1/2 size traction engine or another restoring motorbikes. Also are your preferences metric or imperial.
          #495155
          Ian Richards 4
            @ianrichards4
            Good point.
            Initial posting now updated.
            Thanks for pointing that out.
            #495157
              As always depends on what you're doing. I only have 4 types of steel:
              • For machining on a lathe or milling machine EN1A-Pb. (Or EN1A if Pb isn't available.) They are both free-cutting mild steels, easy to cut and get a good finish, but a little weak. They can't be welded.
              • For general purpose, work EN3B in Bright and Black form. Machines reasonably well, but inclined to tear. Cheap, and can be welded. Bright is finished, which saves time but it can warp when machined due to inbuilt stress. Black is unfinished, and doesn't warp when cut. Bright is slightly stronger.
              • Silver Steel and Gauge Plate are heat hardenable steels. In the US known as drill rod, which is a clue. They're used to make punches or anything else that needs to be harder than mild steel. Good for small objects that can be heated with a blowlamp.
              • Piano wire is a hard steel used to make springs.
              Silver steel is easy to use but expensive. If a large quantity is needed, cheaper hardenable steels are available but are trickier to harden. A big blowlamp or forge plus a certain amount of skill.
              I only do general purpose work in Brass, Aluminium and steel where strength, toughness and hardness aren't a priority. If you're into safety critical work like motorbike axles, the steels I've listed are unsuitable. Ask again! Likewise, certain jobs need stainless steels, which are different again. . There are thousands of different steels available for specialised purposes, most of them not used much in home workshops though they might be.
              What sort of work do you intend doing?
              Rather than lay in a huge stock, my strategy is to buy what I need when it's needed in various sizes plus extra if it's remotely likely to be useful in future. It's not so much different types of steel that make stockholding expensive, its the variety of shapes and sizes needed – rod, plate, angle etc, all in Bright or Black form. Again depending on purpose, you may find certain sizes and shapes are far more used than others. The advantage of stocking metal close to the right size is it dramatically reduces the amount of cutting needed – and cutting is a waste of time and money. Not a good idea to turn a 6" block of steel down into a 4mm diameter bolt, or to spend hours sawing small lumps off a 12" girder.
              Lainchy
                @lainchy
                I'm a relative neewbie Ian, but have made a start on Juliet II.
                I bought my small lathe last year, about this time and I made a big mistake buying from a local steel stockholder.
                What I tend to do now, is buy from Kennions… usually in 1ft sections. I would suggest, as many others will follow no doubt, but I would suggest some EN1 leaded, in 1", 1/2" and 1/4", and some flat bar, maybe 3/32, 1/8, 1/4 etc. Try a piece of EN8 too (about £1.60 per foot? maybe), which is of course harder than the leaded en1. The flat bar will likely be EN3.
                £20 will buy you a nice selection. Their prices are very reasonable. I found that buying off eBay was a bit of a mine field too, and everything was plus postage. Kennions prices are very reasonable, and P&P can be done in one go.
                Enjoy
                Edited By Lainchy on 10/09/2020 20:53:05
                #495159
                Ian Richards 4
                  @ianrichards4
                  Thanks Lainchy, that's exactly what I needed to hear.
                  Thanks to Silly Old Duffer too.
                  Best wishes from a slightly more informed newbie.
                  Ian
                  #495161
                  Ian Richards 4
                    @ianrichards4
                    OK, I've had a look at Kennions, what a great selection.
                    I'm a little confused as to whether the EN1 leaded is the same as EN1A and which is the EN8 you are referring too.
                    Thanks for all your help.
                    Ian
                    #495164
                    Phil Whitley
                      @philwhitley94135
                      I am not a model engineer, but the things I make and repair vary from the very small to the very large, and I grab any shape or size of any metal that comes my way. It gets catergorised into strip, bar, tube, angle channel etc for steel, and for all non ferrous, it is sorted by metal type. As new and better stuff is found, I send the less good quality stuff to the scrapman, or give it away to anyone who wants it. If you are going to build a project, just order the stuff you need, to the nearest round amount, and start your metal stores with offcuts and remainders. All you need to know is, is it machinable, is it hardenable, how hard can it be made, and could it be case hardened and be adequate? Most hard steels can be softened, worked and machined, and then rehardened, and old tools are an excellent source of hardenable carbon steel, especially files!
                      #495165
                      Ian Richards 4
                        @ianrichards4
                        Such good advice.
                        Thanks
                        Ian
                        #495168
                        Bill Davies 2
                          @billdavies2
                          Strictly, Ian, the EN series is obsolete (introduced during WW2), but EN1A is the weakest of the mild steels. It is offered with and without lead, and the leaded version must not be welded or brazed, as it formed a weak joint. Both machine well, especially the leaded variety.
                          Bill
                          #495179
                          Mark Rand
                            @markrand96270
                            EN1A machines easily, but the lead (Macready's do a tellurium doped version with similar benefits) makes it rust if you even look at it cross-eyed. It is also VERY soft.
                            Worth bearing in mind if you are making anything that won't be in a protected environment.
                            EN8 is 0.4% carbon steel and a bit tougher. Can be hardened fairly easily and isn't quite britle as silver steel when not annealed. Also not as hard. Good for wearing parts as opposed to tools. Much like EN3 in the annealed condition, machines like treacle unless you can use high speeds.
                            EN16 and EN24 can be very useful if you are making gears, nuts/bolts, IC engine cams etc. but by that time you'll have a better idea of what you need.
                            If you are planning for the long haul, check on the prices for longer lengths of stock. It''s upsetting to find that you could have bought a 3 metre length of bar from a supplier for twice the price that you just paid for a foot of the same from a different supplier.
                            #495184
                            Paul Lousick
                              @paullousick59116
                              When I first set up my workshop, I purchased a lot of steel stock, some of which is not used after many years.
                              My advice is to make an inventory of what you intend to build, go thru the drawings and make a cutting list of the materials that you will need for the build and add a bit extra for each of the sizes that you require. That way you will have spare steel in the sizes that you actually use.
                              When you buy the steel, ask if they have an off-cut of the steel section you require but a bit longer.  It is often sold at a discounted price.
                              Paul
                              Edited By Paul Lousick on 11/09/2020 00:08:38
                              #495189
                              duncan webster 1
                                @duncanwebster1
                                EN1A is now 230M07
                                En1A Pb 230M07 Pb
                                EN3 070M20
                                EN8 080M40
                                in the last 2, the first 2 digits refer to the manganese content, te last 2 to the carbon content, thus 070M20 is roughly 0.7% manganese, 0.4% carbon. A lot better information than an EN number
                                #495192
                                Old School
                                  @oldschool
                                  I buy my metal from a company called M machine, they have a big range of material and it’s all sold by grade, I like to know what I am buying. Plus they are very helpful.
                                  #495193
                                  Thor 🇳🇴
                                    @thor
                                    Hi Ian,
                                    Much good advice given in the previous posts. I too buy materials from Kennions and M-Machine. If you want to make steam engines you can of course buy sets with castings and you will get all (or most of) the materials you need. If you want to make your steam engines from stock material you may also need some Cast Iron, Brass or Leaded Gunmetal (LG2) for making the cylinder, glands, Steam Chest and so on. For steam engines mainly running on compressed air I use Cast Iron for the cylinder and piston. For steam engines that I run on steam I use LG2 for the cylinder and makes the piston and piston-rod from free-cutting stainless steel (303), I also use the same material for the slide-valve and rod. Reduces the chances of corrosion. Good luck with your engines.
                                    Thor
                                    #495197
                                      I mostly buy my imperial stock at shows so that tends to be 12" lengths but if ordering tend to go for the suppliers that do 2ft lengths. I like to keep the following steel in stock and before a show will go through what I have and list what I'm getting short of. I also keep a piece of paper and write down anything that I'm getting low on as I use it up so check that too.
                                      EN1A, 1/16, 3/32, 1/8, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8, 1/2, 5/8, 3/4, 1, 1.5 and 2
                                      303 stainless 3/32, 1/8, 3/16, 1/4, 3/8
                                      Silver steel 3/32, 1/8, 3/16, 1/4, 3/8
                                      EN1Apb Hex 1/4, 5/16, 3/8
                                      EN3 flats 1/8 x 1 & 2, 3/16 x 2, 1/4 x 1 & 2, 3/8 x 1 and 1/2 x 1
                                      As mentioned above at the start of a new project a good way to get to know the drawings is to work through them listing what material is needed, also think about how you will hold and machine the part so enough length can be allowed for that.
                                      For metric stock I tend to buy on line as not many of the ME suppliers stock metric materials, upto 12mm dia I tend to buy 3m lengths (posted as 3 x 1m) as it works out a lot cheaper than short 300mm length, upto 25mm by the meter and 500mm lengths above that. I keep a slightly larger range of metric than equivalents above as that seems to be what I'm using more of at the moment on stationary steam and IC engines.
                                      #495204
                                      Ian Richards 4
                                        @ianrichards4
                                        A BIG THANKS TO EVERYONE WHO HAS CONTRIBUTED INFORMATION.
                                        I'm overwhelmed by not only the quantity, but quality of the advice given.
                                        Many, many thanks
                                        Ian
                                        #495210
                                        derek hall 1
                                          @derekhall1
                                          This is a good example of why this forum is so good!
                                          Btw it may be a good idea to introduce some sort of colour coding to the different types of steel that you intend to get, it can be difficult determining one type from another if they all get mixed up
                                          As mine have……….. (unhappy face)
                                          Regards to all
                                          Derek
                                          #495226
                                          Jim Nic
                                            @jimnic
                                            A point to bear in mind is to buy material from a known supplier, to a particular specification if necessary, and not to use bits of metal of unknown spec from unknown sources such as skips or scrap merchants. There have been a few posts on here over the years from newbie modellers asking why they can't get an acceptable finish on a piece of freebie material.
                                            Jim
                                            #495232
                                            IanT
                                              @iant
                                              I have good stocks of mild steel "scrap" the majority of which is (fortunately) free-cutting. A small stock of this for general use would be useful – it is certainly the material to use when starting out turning/machining steel.
                                              However, some times I either need to be sure of the material type or need a specific size – and this needs to be purchased as required.
                                              So my advice would be if you can get it for free, then do so but just be mindful that you can only really guess what it is (unless the source offers certainty) but otherwise purchase as required.
                                              Quite often you will need to buy more material than you need anyway (longer lengths etc) – so your scrap bin will grow anyway (just be sure to mark the off-cuts so you can remember what it is).
                                              So, in general, I wouldn't buy stock on 'spec' – but if you can get some good freebies – then why not?
                                              IanT
                                              #495237
                                              Anonymous
                                                For small sizes of steel, below 1-1/2" diameter, I buy standard 10ft lengths from commercial suppliers. Likewise I buy the standard 20ft lengths of hot rolled steel. For hot rolled it is cheaper to buy the full length than a shorter length. I also buy full 1m x 2m sheets of steel. After a number of years I've built up a good stock of steel, such that I don't need to buy much now. I mark the steel before storing, on rounds I stamp the EN number on the end.
                                                I don't use aluminium on my traction engines, other than for fixtures. I have bought a lot of aluminium section and plate for work. Section is bought in standard 20ft lengths and plate cut to size from commercial suppliers.
                                                Silver steel and gauge plate comes from Coventry Grinders, usually in 500mm lengths.
                                                Cast iron, bronze and brass come from M-Machine (cut to the length I need) or Macc Models nearest standard size. I normally add a bit for fumbles. So if things go right I build up a small stock. Plastics come from a local supplier (EDP Plastics) in Cambridge.
                                                I rarely buy material from Ebay. Usually only when it's mega expensive elsewhere, such as tungsten alloy, or I just need something for making a fixture and don't care about the machinability or finish, Such as this lump to make a former for the engine chimneys:
                                                #495243
                                                  Posted by Jim Nic on 11/09/2020 10:18:10:
                                                  Jim
                                                  +1 to that! Starting out I almost gave up because mischance led to my scrap box containing nothing but obnoxious metal! Decided my mini-lathe was rubbish because it couldn't cut metal, when given machinable metal it performed well!
                                                  Problem with scrap is many manufactured items are made of alloys specifically chosen for properties other than machinability. Cutting tools like lathes, saws, and milling machines work best with metals where the specification mentions good machinability or 'free cutting'. Manufacturing has a wide choice of metal bashing methods, and don't take home-workshop needs into consideration at all; threads are rolled not cut and grinding is much used instead of machining.
                                                  Similar issues with DIY store metal. Apart from being expensive Aluminium is too soft and steel gritty. Their Brass is on the inferior side of OK. Basically, DIY store metal isn't aimed at machinists. Don't be put off if it misbehaves.
                                                  My advice: at first avoid unknown metals like the plague. Before exploring scrap learn the ropes with free-cutting metals. Once you know what to expect from friendly metal you can tell instantly if an unknown material is causing trouble rather than the machine, blunt tool, or learner driver. Once materials are identified as 'difficult' they can often be used by changing technique, but wild guessing as a way of discovering how to proceed with them is painful. A little experience with decent metal first works wonders.
                                                  Phil P
                                                    @philp
                                                    I get quite a few bits of random material from our scrap bin at work which so far have proved to be decent quality as you would expect.
                                                    But we have a twice yearly auction at our model engineering club and quite often there are materials to had for pennies, you should see my stock of cast iron, brass and aluminium bar built up over the years.
                                                    The steel obtained from the club auctions has been very dubious though, I always give each piece a trial machining before it goes into stock, I reckon around 60% of it I take to work and dump it in the scrap bin having marked it with a felt pen so I don't pick it out again later !!
                                                    Phil
                                                    #495262
                                                    Martin Kyte
                                                      @martinkyte99762
                                                      As a beginner always go for free cutting steel unless your project calles for something special. You have enough to learn with everything else so give yourself a break. If you are buying small amounts (unlike Andrew) buy as you need, you only hve to think a couple of days ahead. As an aside settle on a size for hold down fixings to T slots, angle plates etc and buy a few lengths of studding that size along with a bag of nuts and washers. When I started half my time was spent making studs and the like for setups.
                                                      regards Martin
