I have what I best describe as a button insert which I brought some time ago for another project but never got around to making a holder to fit into the lathe.
What would be the most useful steel type to use.
I have a piece that is approx 1/2" X 1/2" steel bar of unknown type but I have a very good idea that it is key steel as that is what I would of most likely had from my Plant mechanic days and it was in my toolbox with other square section pieces.
And as that would have been the only reason for having it in the first place. Now that I am doing model engineering all other material that I now own has been brought new and not square section.
Could that be used as a holder the button is only 6mm diameter. I know whatever I use will need to be machined to suit the insert.
Edited By Dalboy on 24/02/2023 12:22:00
