Steel for cutter?
Steel for cutter?
Home Forums Materials Steel for cutter?
  • #448329
    Vic
      @vic
      These are ridiculously expensive for just occasional use. I’m sure I could hand cut something similar myself but what steel to use that I can harden easily? A slice of silver steel would I’m sure do the job but a 2” bar would be a bit pricey when I only need an inch or two. Any ideas of suitable stock sold in short lengths? TIA.
      Vic
        @vic
        #448332
        Jeff Dayman
          @jeffdayman43397
          Oil hardening gauge plate, cut a washer shape out of it, mount on a mandrel to profile it, chisel the barbs. Heat treat will be a challenge though, to get it hot enough without the barbs burning. The supplier of the ones in your link may use a clay pack or ceramic wash and inert gas furnace heating to prevent burning. The techniques and care needed may explain the prices for the commercial ones. These ain't a D bit or single point lathe tool……
          #448339
          JohnF
            @johnf59703
            Vic, have a look here **LINK** might do your job ?
            Or google "Angle Grinder Rasp"
            Edited By JohnF on 22/01/2020 23:18:54
            #448340
            Paul Lousick
              @paullousick59116
              Have you searched on ebay. Found these for using on an angle grinder.
              Vic
                @vic
                Thanks for the comments and the links folks!
              Home Forums Materials Topics
