I have used before the method of a slight distortion of the shaft in similar cases where you just trap the pin in a vice with a 12 mm hardened dowel at 90 degrees and it distortes the pin just enough to make it a press fit localy which you can't see when installed won't fall out, and dosn't weeken the pin. I use a small V block in the vice to hold the pin. Just try it on a scrap piece and I think that will do.
David
Edited By David George 1 on 17/01/2017 23:04:59
Edited By David George 1 on 17/01/2017 23:06:42
