EN 16T is ideal for what you are doing and is easily available.
EN16T, EN16 steel stockholders and suppliers, delivering to the whole of the UK. This grades is commonly supplied as EN16T to the BS970 specification. It is a low alloy high tensile steel supplied with a tensile range of 850 to 1000 N/mm² depending on ruling section. EN16T has a good resistance to shock with excellent ductility. It offers relief from temper brittleness. Subject to ruling section larger sizes in EN16 can be supplied in other condition such as EN16R and EN16S. EN16 as rolled (un heat treated) is also available, usually in larger diameters. EN16 is an alternative alloy steel grade to other chromium and nickel chromium high tensile steel specifications, offering excellent ductility, freedom from temper brittleness and is readily machinable in the supply condition.
David
Edited By David George 1 on 15/01/2017 21:08:27
