Hi Jens,
I would also like to add that it may depend on the size and type of engine. I have not used C45 but from what I have just checked on it’s a high carbon steel with a high tensile strength. It may actually be ‘overkill’ for your application. What type of engine is it and how will it be used.
If you have a source of C45 it (ie it might be free
) for me it would depend on a couple of factors – does it machine well to a high finish or does it need to be heat treated and ground to obtain such. Personally I’m not in favour of the latter without the right equipment though I do know people who case harden and just lap with success
I have used so far EN24t for crankshafts. This turns well and providing the tool is sharp for the final cuts will give a very good surface finish which can then be lapped/honed/polished to a high degree. It is a very tough resilient steel ideal for the purpose.
I have made liners from cast and high tensile steel using cast iron pistons. Both materials lapped very well but the steel liner gave a better seal. The last engines used readily obtained EN1a – a free cutting mild steel – for the liners again with a cast piston. I did not get the lapped surface finish (visually) as I did with the high tensile steel but the quality of fit of piston to liner was as good as could be wished for and has improved considerably with running. How long that will continue remains to be seen but I would certainly use that combination again. These were all diesel engines so required good piston/liner fits.
Obviously it is a much easier material to work especially when cutting ports in and I have not noticed any distortion after machining. Some commercial engines have used this combination and I think you will find the Meketmyer brothers used it on their world beating high performance team race engines.
Hope this helps a bit more
Regards – Ramon
Edited By Ramon Wilson on 25/08/2011 20:18:41
