Steel brick
Steel brick
Home Forums Materials Steel brick
  • #216883
    Geoff Lewis 2
      @geofflewis2
      i am looking for a lump of mild steel measuring 8 3/8" x 10 1/8" x 2 7/8"
      reasonable price considered. offcut ok
      i have for disposal a fine piece of round section steel. not sure of it's composition but it submits to filing ok.
      a photograph is attached.
      the outer diameter is 10 3/4" and the stepped down diameter is 9 1/2". overall height of piece when laid flat on't floor is just over 3 5/16". depth of reduced diameter is approx 15/16"
      I really want to swap or come to some sort of arrangement if purchase is necessary and could possibly meet up for exchange or whatever
      Edited By JasonB on 18/12/2015 19:58:58
      Geoff Lewis 2
        @geofflewis2
        Lump of MS required for carving with milling machine
        #216888
        Martin Connelly
          @martinconnelly55370
          Location always helps with a request like this.
          Martin
          #216895
          Geoff Lewis 2
            @geofflewis2
            Sorry, I should have mentioned I live in Cardiff area. I have also tried to upload about 6 photos but it keeps dropping four of them out. I haven't quite got the hang of this thing yet and the print in this box is so small I can hardly see it?
            Many thanks. How do I edit the posting?
            #216901
              Posted by Geoff Lewis 2 on 18/12/2015 19:19:07:
              Geoff,
              Members only get a short period in which we can edit our posts [after which, the option disappears from the menu].
              If there is an important change that you need to be made, you can ask a Moderator to do it.
                That means your image is huge or the overall upload size is to large. Try uploading one at a time, they will be cropped to 1024 pixels in the largest dimension anyway (keeps page load speeds sensible for people viewing on slow connections).
              Home Forums Materials Topics
